battery problem!
I have a battery pack, made from 6 aaa nimh batteries. I installed it in my 1/16 kubelwagen. everytime I charge it, it will take about 300mah, then I was pormpt it is full charged( I have a triton charger). I measure the voltage is about 9v. but the car does not run as long as before. about 2 minute running. I measure it again, about 8V. redo the charging, take another 200mah. then stoped.
anybody know what is going on here?
Perhaps someone in the Auto forum can help. - Calvin[:D]
Ni Cad batteries occasionally need to be deep cycled you need to put a resistor across the battery to make sure it is fully discharged then try recharging it.
Have you tried RCUniverse, they’re sure to have an answer for you.
