Ok, I have a little question for the masses.
This morning I recieved four Panther barrels in the mail, but when I compaired them to two others I have, something’s wrong! The second set looks right but the others are much shorter. So looking at some pictures I think they are either STUG 111’s or maybe even Tiger barrels. Anybody know what the actual length of the barrels are in inches?
gary
Check the label, it should tell you which KwK the barrels are meant to represent. Either that or they were designed for different manufacturer’s kits and therefore have different lengths depending on how they would mate up. Are the barrels produced by different manufacturers? Post up photos, that might help in ID’ing your problem as well. [;)]
I’ll try the picture post tonight. The real problem is that the odd barrels were just wrapped in card board sleeves with no markings. Right now I have so much loose stuff that I need to get it organized
gary
The Panther barrels were the longest of the 75mm. They were the KwK 42 L/70. The Panzer IV’s were the much shorter L/48.
Did you get these off e-bay or similar? Quite possible they aren’t the same barrel for the same vehicle if they are different lengths.
I bought them off a shop in CA on two different occassions. Both were supposed to have been for a Panther, but two are completely different. Now I’m thinking Stug III. They’re not for a Marder II, and I don’t have an early Tiger get at the house (I know I could always use a couple).
gary
