I have added a 3rd badge and it doesn,t show how do you do mutiable badges, or have the cycle through one at a time?
thanks
jd
thanks
jd
Sherm you have to string the links all together in the box with no spaces in between and you can usally fit about 5 or 6 GB badges. If you want to have them rotate one at a time then you need to make a gif file and host it on photobucket and then put the link in the box. If you do not have a program to make a gif file I just bought one and I can make one for you. Just post all three GB badges you want to use and I can make the gif file for you. Then all you have to do right click on it and save it on your computor. Then post it to photobucket.
Soulcrusher[oX)]
Thanks for the reply, what is the name of the program that you use?
thanks
jd
Covered extensively here:
/forums/1157310/ShowPost.aspx
