badger needle juice
Is it correct to add a drop of badger needle juice to the paint cup (in a Badger 100 LG), after it was cleaned, and spray it? I read that this help to prevent paint clogging att the tip.
Thanks in advance
Jose
I’ve not heard that. I put it on the front 1/3 of the needle manually. Dab on the finger and rub on the needle. Careful of that tip. It is SHARP!
That’s what I do…
I put a drop in the color cup and rub it around the cup to coat it and help the paint not stick as bad in the cup to aid in cleaning. It is best to coat the front half of the needle with Needle Juice and I do it by spreading a layer down the length of the front half of the needle and then spreading it with my finger. Ken at Badger takes the cap off the Needle Juice and sticks the needle into the bottle half way to coat it and then lets the excess drip off back into the bottle and then inserts it into the airbrush body.
