Any one got any info or experience with this brush at all? it sounded like a 155 with smaller tip but upon picture inspection, u see that the cut handle/needle chuck/spring assembly seem to resemble those of the 100 series. Looks like a competition to the HP-BCS.
I have one.
It is a special Anthem 155 that Jason Livery designed and Badger made.
It has an Omni trigger with a smaller tip and sprays a lot like the 155 except a little finer.
If you already own an Anthem, you can order the 3155 needle and mate it with the Crescendo’s fine tip and nozzle and you have your own home made Hybrid. Check the parts list for the Hybrid and you’ll see what I mean.
E
Not exactly. You need the Omni body to have the same airbrush. [;)]
True, but the “home made” will give you the same performance with the specs I mentioned. And that info came straight from the Badger 3155 customer service area. As you have said on numerous occasions, outstanding customer service before and after the sale!
E
