bvallot: I did check out the NMF group Build you suggested and it was great, thanks so much for steering me there. Lots of good ideas and tips. Best thing about this forum!
Shipwreck: I used two 1 oz. bottles of Polished Aluminum. A little goes a long way. The Alcald did OK over the Tamiya gloss black. I did not have any Alclad surfaces pull up when I masked them later. Last night I sprayed some of the lower engine nacelles Stainless Steel, and had to mask over the original Polished Aluminum; the masking came off just fine with no issues.
However, the original purpose of putting the Stainless Steel down was to emulate those panels that were stainless to disseminate heat and I did not get that effect. Instead, it looked almost just like the Polished Aluminum that it was sprayed over. I figured out (later, of course) that I should have put more Gloss Black down on the masked portions. The Stainless Steel was reflecting the undercoat it was on, which was Polished Aluminum. Lesson learned here is to re-apply the base coat on any panels you want to overspray with a different Alclad color. Probably should have figured that out beforehand, but I didn’t. Story of my life [*-)] So I guess I will get to re-mask and do it all again.
Cheers, Bob
