hey guys I finished up the harrier today, Hasegawa kit 1.48 , paint is craft acrylics
Wow, fantastic detailing. I love the way you blend the colors in just like an artists does, seamless.
Toshi
Wow, the paint looks so good it almost makes the Harrier an attractive aircraft! JOKING- great job there!!!
Really very nice. Glad to see some else using craft acrylics. Nice build!!!
Excellent build, very well done.[Y]
Awesome job. I love it.
Great! I like Harriers and yours is fantastic!
Outstanding!! [Y] [Y]
Stellar build! What craft paints did you use?
Sweet!!! I’m building this kit for the Marine Corps GB. Just getting ready to start paint.
Steve
thanks guys, I used these 4 colors to mix everything
I’m a craft store acrylic fan as well. That finish is gorgeous. That’s top shelf work there. O.O
Did you prime the kit first; I’ve had trouble with adhesion from those paints.
No primer, I only “spot” prime where I use the bondo. I find these paint stick awesome, just need to get the thinner ratio right. Each color is different and I use a hairdryer after each coat and I can run the paint under a tap and its very hard to remove when cured. I tried the Vallejo air one time in the past and it peeled off like a layer of rubber !
Also I seal them on with duplicolor acrylic lacquer and finish with Grumbacher matte varnish
That is pretty outstanding work !
beautiful work
Dude! That is insane! Craft acrylic?? My mind is blown. That’s some kung fu ninja skill right there. Sorry if I missed it, but what did you use to thin? Washer fluid maybe?
Thanks!
Yeah for my thinner I use 50/50 washer fluid/water with a few drops of glycerin, how much you thin the actual paint itself is just trial and error
