Got back to modelling after losing my job, helps to clear my head and forget, fortunately with two model contest coming up, and a load of model, I got started on my two lastest kits.
Two Trumpeter Tank Destroyer, The E-10 Prototyp the new SU-152
Both are the same scale, and were (or could have be) Fearsome adversaries.
The size of each is very noticeable.
This Tutorial is to show the basic of my method for painting and finishing scale models, they are base off FSM articles, tips I heard for other expert, as well as from the Forum.
The Tutorial will be two parts, the first will be camouflage with the E-10, while the single coat scheme, will be with the SU-152.
1.The First step is of course to finish assembly, this included adding all PE part, sanding, gap filling and finale touch up, equipement tools and wheel will be added later, At first, I was thinking of adding the side skirt later, but for a perfect camo, it needs to stay on.
Most of what you see came with the kit, all the PE parts (except the handle bars, there just bend copper wire) and one of the tow cable is a piece of rope. The putty on the front is to cover the spot where the headlight went, I removed it because this prototype possible wasn’t fitted with one.
- Before the primer goes on, I need to add a coat of Metal Primer. This Tamiya product adds adhesion to the PE parts so when the primer (and paint) comes off, it won’t peel off, it will stay on.
Then comes the Primer, Tamiya grey will do nicely.
Give it at least 12 hour to dry, don’t add too much, you may regret it.
Thats all for now, next step will come soon.
Feel free to add comments and additional advice.
Magellan Dufour
