Ark Models BT-7A review
BT-7A “Russian Artillery Tank”
Manufacturer: Ark Models Russia
128 parts, no photo etch or clear parts, 4 decals.
Price: about $10
The BT-7 was made in 1934 as a series of cavalry tanks developed by the Soviet Union. These tanks had poor armor, (which became painfully evident during world war 2) but reasonable arnament. The BT stands for “high-speed tank” in Russian. One of the main features of the BT-7 was the Christie suspension. The BT-7A was an artillery support tank that was armed with a 7.6 cm howitzer. Otherwise there is no difference from the BT-7.
I bought this kit when I was in Russia, this summer, and it seems like it’s from a new company. I saw Ark Models’ kits in a lot of the stores. The company seems to mostly make German and Russian World War 2 armor, and World War 2 era Soviet aircraft. The box art was decent, but it shows the tank with a chain, when none is provided, and a few of the parts in the assembly are not shown.
Inside the box are 5 sprues of light gray plastic, but a lot of the parts have nasty ejector pin marks that have to be dealt with. The assembly begins with the lower hull The instructions show parts B7, B7, and B8 are sandwiched between parts A6 (A5) and A3(A4)… I assume, the instructions are confusing throughout the build. Anyhow, the parts do not fit, so I left them out. These are only the sides of the hull. The whole hull is made in 10 parts, something I find annoying, not to mention that when I attached D2 to the hull there was a few large gaps.
I skipped around a bit and started assembling the turret next. The main parts went together well, although there was a seam to be filled. The part M4 does not fit onto the turret, so I had to sand off a part of it. Sadly there is no interior whatsoever. The main reason I skipped around with the instructions was because there are lots of parts that are attached at times that do not make sense, for example towing hooks were attached after the fenders, making it hard to glue them into place. I thought that the kit’s tracks would make the build easier, I was wrong. A lot of the track parts have incorrect attachment points and require some surgery to correct. Luckily there are extra parts left over, so you can always get another chance at them. When attaching the upper part of the tank to the lower there are some nasty gaps to be dealt with.
I painted my model with model master enamels and weathered it with a Tamiya weathering stick (really good actually). It can truly be said that the kit’s decals are its highlight. Although only one of the four decals is shown in the painting instructions it is the only part of the kit that had nothing wrong with it. Overall this was not a particularly pleasant build, and the many fit, quality, and other issues make it a kit for experienced modelers. While it is completely inferior to Tamiya’s BT-7, this kit does provide an interesting subject to build.
ozzman
I was thinking of building a BT-7. Any pics?
This is not a BT-7 this is a BT-7A there are some differences in the turret, sorry i do not have pictures, but i suggest you buy Zvezda’s or Tamiya’s kits
You left out a rather important detail in your review…
Scale…
Thanks for letting me know, the model is in 1/35 scale.
