i did a search here but those threads are a few years old. im looking for a compressor that will be quiet enough for use in my apartment. i went to hobby lobby a few days ago and they had five or six compressors, and a few of them said “quiet running”, but i dont know what their version of “quiet” is. i also dont want to pay an arm and a leg for one. whats the current offerings?
I have been searching for a new airbrush compressor (a quieter one) myself, and have commented in this forum how so many of the spec sheets I find on mfgs web pages lack a noise figure. One that I am seriously looking at right now is the Iwata Silver Jet. It has a sound value of only 40 db, way below others I have looked at. 40 db is very quiet.
My only concern is the flow rate. I forget the rate at the moment, but when I went to find the rate of my brush I was unable to find it. Most spec sheets on the web for the airbrushes themselves lack the flow rate value.
I find trying to match compressor and brush very frustrating because so few web pages really give good specifications for their products.
I suspect the Silver Jet, being one of Iwata’s cheaper compressors, is a bleed type regulation, and the higher the flow rate, likely the lower the pressure. The rated max pressure of 18 psi is right at the limit of what I use. I ordinarily use 20 for matt finish, 15 for gloss. I could probably get by with 18, but not much lower.
I assume with my single action Badger, my main brush, the needle adjustment affects the airflow, but have no idea of the range of airflow with normal settings.
I read a lot about compressors here on FSM, and it strikes me how strange the discussion is all the time… Now an airbrush doesn’t need a whole lot of air, like pneumatic tools. But the compressor has to be quiet. Now I bet (nearly) everyone of you already owns a compressor close to those requirements - it’s a part of your refrigerator. Some 15 years ago I went to a workshop where they fix fridges, and got a frige compressor unit for free. I added a manometer, some rubber hose, and I’ve been using it since then. With time I also added a presure switch, and later also a filter/reductor unit. The cool thing is most fridge compressors are built inside their tanks (the housing is air-tight and serves as a tank), so you don’t even really need an extra air tank for it to operate. So I say it’s worth to look for parts and spend some time - relatively cheap you can get yourself a fine compressor, perfectly suited to your needs and the application. Hope it helps, thanks for reading
I’m not so sure about that, although Iwata don’t quote a noise level for it, most dealers including some official distributors are quoting 50-57db.
As an airbrushing rule of thumb, 0.5CFM is an acceptable flow rate - this will obviously vary from brush to brush though, 0.33CFM seems marginal
I believe that the Silver Jet is bleed regulated & when you say “right at the limit” I thinks that you may be correct.
Having a quick look at the Sparmax site (Sparmax make most, if not all Iwata compressors), the Silver Jet looks very much like the AC-27, with the 1/8hp motor replaced with a 1/10hp one & some minor cosmetic changes. It’s a shame that Sparmax compressors don’t seem to be more readily available on your side of the water, as they are superior to many other imports, but don’t carry the premium of the Iwata name…
… Hold on, Merriartist do a range of Sparmax compressors, including the AC-27 with 1/8hp motor for pretty much the same price as the Silver Jet sells for ($140ish). You just need to ask yourself if you could live with that lovely electric orange finish;
For some reason, Sparmax had withdrew from most of the retail market in the US, except the compressors. Two of the compressor models are sold at a major hobby store chain called Hobby Lobby. It is most everywhere in the midwest of US, but not where Don lives. (About 90 miles away from him.) There are a few mail order seller left. The AC-100 will be a good beginner airbrush that meets your criteria.
stymye, the quote consume very little bandwidth unless it has lots pictures. It was done to address specific questions. We also post pictures often which does take up bandwidth. While I understand your frustration with a slow dialup, but there is no reason to ask the majority of us to cut back on activity because of the few. I am sorry.
I think it depends on whether the quote is the original post or a more recent comment. Sometimes a thread splits and goes in different directions. In that case a quote is needed to let people know which branch of the thread your comment is about. I generally do not quote the original post, but may for those more recent comments when my reply is for that recent comment, not the original post.
I use an Iwata Silent model. It’s super quiet. Auto shut off when not in use. Very light with handle and brush holder. Got it for $100 off of Ebay. Love it.
I have the little black Iwata compressor. Its is unbelivably quiet and only runs wehn you push your airbrush button. I have it in an apartment, and it is super quiet. Also best value for money I think because it comes with regulator, auto shut off, and special hoses. I think i got it off amazon.com for under $300. Really nice, I am very pleased with it. I used to use a Paasche and i will never go back.
I too went on such a search about a year back. The really ‘silent’ ones was way outside my budget ($1K+), I finally settled on the Grex compressor. I saw it demo at a model show, with all that background noise, you could hardly hear the thing go off. In my quiet work room, you definitely can hear it, but you can easily hold a comfortable conversation with it on if you wanted to.
It has auto shutoff, so when you are not spraying, the compressor is not running and making any noise. Has a pressure guage and moisture trap built in and can be found online for $200 (or under if you dig a bit).
That is a nice little compressor and I recommend it as I used it with Ken Schlotfeldt at the Nationals in AZ back in '04. I thought it was nice and very small and portable to boot. [Y]
