ANy tips on first AB? Aztek a270
Well… it’s christmas and I just got my first airbrush, an Aztek a270. Its single action and from what Ive read its an entry level one, but god I’m excited! I don’t care what kind of quality it is, its still my first airbrush! So, I was hoping for some general tips on it? Like do I have to use oil based paints, or can I use water based ones which I already have? How do you know how much to thin the paint? How do you clean it? So many questions! Im gonna read the instructions twice and watch the informational video, before even trying it, but still, I dont want to take any chances, so any tips? Thanks guys, and merry christmas, chanukka, feliz navidad, and anything and everything else you celebrate! -Ian
My very first airbrush was the Badger 250 ( yeah 250, not 200 or 350 ). It is probably very close to your brush as far as performance goes. I would suggest thinning your paint to about a 3-1 ratio (paint/thinner). If you have a compressor, I would set about 20-25 psi and lay some good base coats and take it from there. HTH!
P.S. - I forgot to mention paint ype. I personally prefer Model Master enamels with it’s own brand thinner as it is very forgiving. Keep in mind that many here prefer acrylics and I applaud them for it, but I’ve never had good luck with them.
E
I also prefer oil based enamels. Much less room for error, but I feel the result is nicer.
As far as how much to thin the paint, just experiment and thin it until it sprays right. I usually just thin by insitinct now.
ALWAYS clean the airbrush as thoroughly as possible. Spray clean thinner through it backflush, and repeat several times. Being an aztek, it’ll probably get clogged anyway, but still. Some modelers produce brillaint results with azteks.
Have fun and post pics of your first project with it. [:)]
Congrats on the AB. I’ve never used the A270, but it looks to be better than the A220 which was my first AB and produced nice results, so I expect that you can do fine things with your new AB. Follow the cleaning and care instructions that came with it. As you become more familiar with your AB, you may find that you can simplify the cleaning regimen.
The real trick to getting a nice finish is proper thinning ratio and air pressure. In my experience, paint consistency varies widely, so you can’t really expect to use an exact paint thinning ratio consistently. If you experiment, you’ll find it doesn’t take too much practice to get the hang of it.
One thing to note is that when you practice, be sure to practice on some scrap styene or other non-porous material such as an plastic milk jug. The reason is that if you practice with something porous like cardboard, it will absorb paints differently than the styrene which is not porous.
