Anti tank gun
Not sure if this is the right place to ask but here goes. I have two of the Tamiya 7.5cm Antitank Gun (pak 40/L46). I would like to add some detail to these. Where can I get turned barrels and photoetch?
Try looking for some at www.greatmodels.com.
Go to the search function and search for the models you have, then when you click on those links you should see an option in the top left corner of your screen to bring up all accessories.
-Mark-
If you use Great Models’ search function properly, you can get a search result that lists all the accessories available for a particular kit. Here is the result for the Tamiya Pak 40/L46:
http://www.greatmodels.com/~smartcart/cgi/search.cgi?terms=AFV35071&boolean=OR&category=Accessories_For_TAM35047
While it’s not a perfect search function (for instance it lists the AFV Club kit as an accessory for the Tamiya kit), it narrows down their inventory to a more manageable list of items.
you could use and mod-up a barrl for a tank if you can find the right type. Here are some.
StuG IIIAusf G Gun Barrel Eduard-EU34034
Well not really. The barrels for a Stug III kit would only go up to the mantlet. A Pak 40 model has a gun tube that extends to the breech. There are plenty of Pak 40 barrels to choose from anyways.
Ok there are? then whats the company’s name and stock number of the item. I have that gun my self.
Here’s some more of what I found.
http://www.squadron.com/NoStock.asp?item=CZHB006
http://www.squadron.com/ItemDetails.asp?item=EU34054
I have looed where I shoe an I can’t find a PE set for this kit.
modelbuilder and White R34
This should help you both
http://www.perthmilitarymodelling.com/reviews/subject/pak40.htm
All the other barrel manufacturers make their version of the Pak 40 too in 1/35.
Jordi Rubio JRU25
Model Point MT3576
Griffon Models 3 variants
Like an earlier poster suggested, go to www.greatmodels.com and use their search function, type in “pak 40 barrel”
WOW it’s not cheap is it LOL thank’s I’ll get me one. Ok I see Griffon Models
GRMLB35004,
http://www.airconnection.on.ca/ABER/ABERGB35/airconnection_ABER_AB35L19.htm
I have some new places to go now. I will look up PE sets on these sites.
Thank’s again
Did you know the AFV Club kit comes with PE shield and aluminum barrel? That might be more economical for you White
http://www.perthmilitarymodelling.com/reviews/vehicles/afvclub/afv35071.htm
