Anti-Slip paint on an Abrams Tank
Hello,
I’ve finally found time to get back into modeling again and have started on an M1A1 Abrams tank. I’m curious to find out what the best way / method to paint an anti-slip coating would be. I’ve never done this before so any help and advice would be greatly appreciated!
Thanks,
Ryan
Welcome to the site! Try this site for replicating the non-skid surface on M1’s. It should be in the Features section, but you might have to look around. He also has comparisons of the available Abrams kits
http://vodnik.net/index_m2a2.htm
Masking the areas and spraying Mr. Surfacer 500 works very nice.
I built Trumpeter’s M1A1 and it has the anti-slip molded in!
I could be wrong, but I know Tamiya and maybe Academy don’t have the anti-slip surface. I know Dragon, Trumpeter and Italeri do.
Tamiya definitely does not.
I posted this question and than found this one so oops on me[:D] Anyway I looked at this sit and it has good info on the Bradley but havent seen anything on the Abrams yet.
I want a diagram of where exactly ther anti skid surface is to be applied; than I want to use a lite coat of white glue and water with baby powder to simulate the surface. It will either work or keep the tank from getting diaper rash[:D]
This stuff is awesome my camera’s battery is dead so I cant really show you how well it looks on my current project but it is very easy to apply just brush on , it is basically textured acrylic paint and is as close to the real thing on a model tha I have ever seen you can get it at most craft stores.
http://www.decoart.com/cgi-bin/Products.cgi?Sandstones
[#welcome]
Welcome to the forums!
I cant add anything to what was already said above, just wanted to say hello and welcome back to modelling [}:)]
Here is a scan of the TM where the nonslip coating goes:
www.members.aol.com/rgronovius/nonslip.zip
Thanks everyone for the timely responses and the welcomes to the forum. I read the article that kaleu provided and it looks like the Mr. Surfacer 500 will work well. Now I just need to find it. I’ll try a few local hobby shops in the morning. I’ll post pics of the tank as I near completion.
Thanks again,
Ryan
Thanks to Rob Gronovius for providing the scan of where to apply the non slip coating. I was just about to start researching that.
Ryan
all pics here
http://smallshopeu.com/M1A3%20John%20Murphy.htm
[img.nr] http://smallshopeu.com/M1A1%20J%20Murphy/IMG_0932.jpg [/img.nr]
AJ
The Mr Surfacer 500 method seems to be a favourite with many modelers today. You could also go the classical texturing route; paint the surfaces that need this effect with liquid plastic cement, wait a couple of seconds, then stipple with an old, short-bristled brush.
There are other options which do not destroy the plastic…as seen two posts up
A LOT of guys are using CASTaCOAT…
AJ
I have built the Trumpeter M1A1HA Abrams with the non slip surface already moulded on it so it was a little easier in that area but it can still be stuffed up be applying to much paint to that area.
Here is a pic of how mine turned out.
HTH
Robert
