Sorry for all my ignorance but I’ve found that the personal advice on here is far more informative and helpful than the things I can find on the Internet…
So if I could throw my noobness at you again id appreciate that… Along side my next motorcycle project I’ve decided to step away and try a car too… Now I know I’m not skilled enough to produce a shiny factory finished car so decided I’d try weathering and do a rusty up vw beetle… That way any mistakes will just add to the effect… So this is where I’m at at in my head I just need to know if this will work so far…
Main body…
Rust colour primer over laid with some different rust tone acrylics…
Coat of matt varnish to seal that… Then some various chipping methods… Salt chipping for big areas and some white glue/liquid mask or hair spray for more subtle chipping…
Then another coat of clear… Not sure if it should be matt or gloss? … Before using washes and powders for more detail…
Followed by a final matt clear coat to seal everything…
Am I some where on the right track or way off?
Thanks in advance
