Another Mig 21
Ok guys, based on your responses to my big Egyptian 1/32nd scale Mig 21 (thanks everyone for your kind responses) I’ve got another one for you. This one is the 1/48th Academy kit. I built this one before I built the 1/32nd kit. As you can see I have a thing for the mid-eastern desert camo schemes. This one is in Syrian markings. Not a lot of after market parts in this one either, again, I did use a resin seat and after market decals. I added some detail to the cockpit and canopy. One thing I like to do on the camo paint schemes is to paint the base color first, the base color on this kit is Model Master Sand flat enamel. I then use Xtra Color paints for the camo pattern. The Xtra Color paint is gloss enamel and it drys much slower giving me more control in my airbrush. By drying slower it tends not to clog up during spraying allowing a much smoother soft line between the colors. I then give the model a few coats of Testors clear lacquer gloss coat and apply the decals. The final finish is Testors flat coat. All paints are cut with a good quality automotive lacquer thinner.
-George-
That’s another sharp MiG-21, George. I’m curious as to what color that camo is- is it grey or green? I can’t really tell on this monitor, sorry. Either way, that is a tight camo pattern.
Got any more Russian a/c underway? We have an on-going Russian jet GB here…
Very nice build!
Very nice!
Go google pix of the Angolan AF Mig 21’s , I think you might become an “African” Mig fan aswel :wink:
Theuns
George, seems you also have a thing for MiGs in general as well. [;)] That is a sweet build, and your paint work really is top notch. The -21 is my favorite MiG, and you knocked yours outa the park! [Y]
Very nice work (again)! Where did you get the Syrian AF markings?
The Xtra Color paint I used for the camo pattern on this Mig actually is a Luftwaffe color RLM 74. It’s a green/gray and seemed to fit very well based on my references.
At the moment I don’t have any more Russian a/c underway but I’d like to do another one in the near future. I currently working on a 1/48th Beech Staggerwing (Roden kit). I will check out the Russian jet GB.
I got the Syrian markings from Squadron. Eagle Strike sheet EP48272 (for a Mig 17) has Syrian markings that fit just as well for a Mig 21.
Thanks for the idea on Syrian AF decals (not enough of those out there in my view).
