Looking for a an Essex class carrier with the scb-27 modernization. Can anyone tell me what kits Revell made depicting these and if there are any aftermarket companies that make detail sets for these kits? Thanks in advance!
Revell made a 1/530 scale kit of that class of carrier under several different guises (Essex, Oriskany, Lexington, Wasp) over the years. Recently it was re issued or slated for re issue as USS Hornet +3 with the ASW aircraft and the Apollo 11 capsule, kit # 85 3014.
Gold Medal Models makes a PE set for that kit
Even with the same kit, check your references before building.
There were 2 SCB 27 modifications, 27A and 27C. The angled deck change for the Essex-class was actually SCB 125.
Once the angled deck and “hurricane” bow was added, the 27 Charlies, got bridle arrestors for the steam cats mounted at the bow. These are those “buck toothed” looking things sticking out in front. The 27 Alphas didn’t get them. The Charlies became CVA attack carriers, the Alphas became CVS anti-submarine carriers.
Check and make sure when you decide which carrier you intend to build. Since I’ve never built the kit, I’m not sure the kit has the option. Doing different carriers means more than just the number on the flight deck!
Have fun with your project.
The reissue has been cancelled. The molds are too damaged to produce without a large (and expensive) retooling effort.
What you sees is what you gets
I listed the kits (forgetting Wasp) in the duplicate thread. I also mentioned that Gold Medal Models makes a nice PE set. EdGrune is correct . . . not all Essex class conversions were identical.
Bill
If you ain,t proud and will work in a smaller scale there is always the U.S.S. ANTIETAM in 1/700 . I don,t know much about carriers except I did NOT like duty on them (to much dingle bell brass running loose , if you knowhatImean !) She,s not a bad kit , and I don,t like to work this small because these old eyes . But , she builds up into a gorgeous shipmodel when done ! tankerbuilder
USS Hornet just reissued by revell germany!
And Revell USA is going to be re issuing the Renwall USS Shangri La in the near future.
one thing about the Revell reissue of the Renwall 27C kit,you need to check to see which ship you want to build,of the 27C+125 ships, the kit will only build Shangri-La, Lexington, and Bon Homme Richard without major deck surgery,there were two groups of 27C+125 ships, with the starboard elevator and crane swapped forward and aft in each set (changing the deck shape in the process),also, CVA-34 Oriskany had other differences, since she was really a 27A, with a later 125A mod, but with steam catapults (grouped with the 27-Cs because of mission capabilites)
also, the 27A set that you build from the Revell reissue of the original Revell kit were CVA at first after they got the -125 angled deck mods, then changed to the CVS mission after doing CVA cruises,they got CVS mission after the Midways and Supercarriers started showing up, as the Straight Decked CVS Essexs were decommed
(showing the work dept:,Essex had ATG-201 and CVG-10 cruises, Hornet had CVG-14 and ATG-4 cruises, Kearsarge had ATG-3 cruise, etc, etc)
Rex
So it sounds like the Revell and Renwall kits build up into different versions of the angle deck Essex Class?
Picked up the Hornet, and the Shangri La in the local hobby shop this weekend.
yes, Stik, they do
they build up into Two of the Four main shapes of the Essex class,Five if you count the Oriskany’s different hull width
the cool part of the Angeled Essex is that you can build them in Air Groups and ASW Air Group mixes so that no two would look exactly the same on your shelf,the Air Groups were in so much flux and aircraft development were so varied that between the aircraft on the deck and the distinctive markings,even if two ships happened to look the same at the same time, the aircraft would give you variety
I once did a build list of the Angled and Straight decked ships for a Steel Navy member,and it is possible to build more variations than the total number of ships built (24),one year, every Angled Essex that was done at that date had a different Antenna arrangement or Island configuration, creating a different look
There is much to learn here I see. Kind of like I do with certain armor and aircraft kits- same base kit into different versions. That is what makes this hobby so fun.
Understatement of the month. I have no idea what these guys are talking about, but I am interested. And we have Hornet here…
We have Hornet AND Shangri La here now according to Chasd 25. Lots of possibilities to be had as described by Rex. Starfighter is putting out decal sheets for these kits to cover markings…
lol, I DO know this info,and I also have more to learn on this subject, hah
let’s just tackle the five shapes of the Essex angled deck ships for a start
there is the shape of the Antietam, the first angled deck carrier in the USN (she actually had two different shapes on the Port side in different time periods)
After the Antietam, there was the Oriskany, completed as the prototype for the SCB-27A straight deck ships
Then, there is the shape of the -27A +125 ships, they were modernised as 27A straight deck and then after serving awhile, got the -125 angled deck mod,later, after they moved from CVA (Attack) carrier use, some of them got mods to become CVS,still the same basic shape as the Revell kit, though
after the 27A+125 batch, the Oriskany got the ACB-125A angled deck mod, making her another one off in shape, the most noticable being the wider hull than the “Hornet group”
3 ships were receiving the SCB-27C straight deck upgrade, and served in that config, then later received the -125 angled deck mod
then 3 other ships (as in the Renwall kit) received the -27C and -125 mods in the same yard period
the two batches of Angled 27C differ in that they have the starboard rear elevator and crane in the opposite order,including moving the hole in the starboard hull that the elevator exits into the Hangar Bay through,you don’t just “glue the crane in front of or behind the elevator”,the deck right in that area also changed between the two 3 ship batches
so, you end up with Angled decks as follows
Antietam (with two different landing area sponsons)
SCB-27A+125AOriskany (wider hull than the other 14)
SCB-27A+125 as the Revell kit builds (7 ships, different for CVA and CVS times)
SCB-27C+125 with elevator entrance forward
SCB-27C+125 with elevator entrance rearward
total of Five different appearances, plus the two additional variations in parentheses
Rex, the Accidental CAG (“ShipWriterTN a very long time ago”)
Were any of the ships change from one ange deck configuration to another during overhauls?
I know the USS Midway underwent 3 different deck configurations, don’t know if any of the Essex ships did though, I’m curious myself!
Charlie
the only changes to the decks, other than repainting, was in the deck cladding materials,and the two different types of bridle arrestors (called “catapult horns” by some people),deck cladding,many different thicknesses of different materials in sheets, plus paint and coatings over that,Alan Raven’s old Essex book has a 1/600 drawing of Intrepid, with all the cladding and coatings marked in (8 different ones at that time?)
before the sponson type Van Velm Bridle Arrestors were installed, there was a spindly looking type that looked like it was made up of steel rods in a lattice pattern
I would really like to build a model of Lexington, she was my last ship before leaving active duty, but want to do her right.
