AMT X-Wing Rebuild - Complete
I posted this in the Star Wars GB going on right now, but I’ll post it here too. I’m rebuilding an AMT X-Wing that I built as a kid. My plan is to build it as Blue Leader’s mount from Rogue One. I want to put it in a diorama undergoing some maintenance at the Yavin Base in an homage to a Hoth diorama my dad built that was featured on the cover of Scale Modeler back in the 80s. Here’s what I’m starting with:
I also have most of a spare kit to work from so I won’t be afraid to mess up too much, or get to bold with cutting panels open:
I’d also like to scratch up some droids like a gonk or a treadwell. Wish me luck.
You have my attention! :smiley:
Hurry, cant wait! Chris
OK, so I know it’s been awhile but it took a lot longer to strip the paint job I did as a kid. I got it to where it’s as good as it’s going to get. I’ve been slowly working on the cockpit. Here’s the stock kit part:
Not very accurate to what you see in the movie. I’m not going to 100% accuracy, but anything would be better than this. I cut down the spare instrument panel from my Revell A-6E that I just finished and grafted it on. I also removed the “seat” and will be replacing it with what I think is a WWII aircraft seat, but I couldn’t tell you what kit it came from. It was just floating around in a spares box. Here’s where I am right now:
I filled in the spaces with Perfect Plastic Putty and it looks a lot better. You can also see the seat I’m going to be using. I need to check some reference pictures for the side consoles to figure out what I’m going to do there. I still need to tackle the area behind the seat, scratch-build a targeting computer, and then hit the front panel.
I didn’t take a picture of this, but I cut open a panel on the bottom of the ship, and plan on opening up a panel behind one of the proton torpedo launchers and build that. I’m also going to have one of the engines exposed, and open up the nose. I want to get more ambitious, but I don’t think it would be good for me [proplr]. After all, there’s still the rest of the diorama to build.
Just to prove I’m still plugging along on this, here’s where I’m at.
I drilled out the proton torpedo launcher tubes and removed a panel so I can build the launcher inside.
I’ve also modified one of the engines so that it will be visible when the panel is open. I still have a lot of work to do here in modifying the parts so that the panel would actually fit closed over the assembly.
Lastly, here are some card stock templates I made for the cockpit. The plan is I’m going to use them to cut styrene parts from a sheet then glue them in position once the cockpit is in the fuselage and then putty up any gaps. Then I’ll paint it all up. I’ll get the hard to reach areas painted before I put it in. I still need to build the targeting computer as well.
Luke was part of Blue Squadron in the book, but since the movie was shot on a blue screen, the blue markings wouldn’t work in 1977. So Blue Sqdn became Red Sqdn.
Thanks for reminding me of that Rob. I remember reading the book as a kid and then asking my dad about the change in squadrons.
Looks fun. I made the mistake of a search for Tie Fighter today for some reason and suddenly found myself buried in one of those Star Wars sites. I have no clue where all this history and back story that can run for pages comes from no matter the prop or the character comes from.
That’s something I love about Star Wars: the rich universe and background. It completely blew my mind when I learned that every character in the Mos Eisely cantina had a name and backstory. It was all over from that point forward.
Still plugging away at this, getting all the internal parts together and finding suitable greeblies to stuff inside. With just a couple of little things here and there, most of them are done. They are mostly car parts with some absolutely random things I found scattered around my spares boxes.
The cockpit is also ready to go into the fuselage. I’m going to do the coaming panel and sidewalls after it’s inside, I think it will be easier to get everything lined up properly that way. I rigged up some hoses by the seat and built the targeting computer. You can’t see it very well in the picture but there are some foot pedals under the instrument panel as well.
Great re-imagineering.
Thanks Duster! I finally feel like I’m moving forward on this project since I don’t need to spend all my time looking through spares for greeblies
I have a lot of the greeblies put in. Quite a few went in around the astromech port and I couldn’t get a good picture of the area. Here’s the completed engine:
The proton torpedo launcher:
Access panel under the ship:
And lastly, here’s where I’m at with the cockpit. I still have to fill some areas and sand, then add in some more greeblies and paint it.
Only a small update for now, bench time has been at a premium since school started back up this week. I’ve finished the cockpit except for the coaming panel. I’m going to save that until after I’m done painting and weathering. I found a few gaps on the wing to take care of and then I should be able to put it all together and start painting.
[8-|][:D]cool job!
Thank you!
It’s looking good. This was one of my first Star Wars kits I ever built, along with Vader’s TIE and R2-D2 and C3PO.
I started working on the larger Poe Dameron black X-Wing. It is a pretty nice kit, although I really wish it came with decals and not pre-painted markings. It was a whopping $12.50 on clearance. I also got the two X-Wings that have lights and sounds for my son, one black and one grey.
Kids are very lucky with today’s Star Wars model kits. Even these cheaper snap kits are very good model kits. MPC’s original kits were quite tricky to build and much detail was simplified.
Thanks for looking in Rob! The old kit of Vader’s TIE was the first I built when I came back to the hobby. I have Poe’s X-Wing in the stash. I wasn’t sure about it when I first saw it, thinking it was too “toy-like” but it was on clearance so I bought it. I was pretty surprised at the amount of detail in it when I got it home and opened it up. My son is very interested in gettig the light up and sound kits that he can throw together and play with.
The non-lighted/sound X-Wing is a pretty nice kit, biggest downside is no pilot and pre-decoration. Of the smaller lights and sounds kits, that TIE fighter is a pretty nice kit that might be close enough in scale to the larger X-Wing. It is huge compared to the other light/sound kits.
That’s good to know about the TIE Fighter kit Rob, good looking out. And I agree with you about the downsides of that X-Wing. I really wish it came with a pilot, but I’m pretty sure I can fix the paint job on it. I couldn’t do much worse.
