Wanting a change of pace from building military a/c, and having never tried a short-run kit, I thought I’d give the 1/72nd scale aModel Lear 60XR a try.
Certainly an attractive bird, the modern Lear Jets with their rear delta fins, can stand out among the various biz-jets flying today.
The kit box gives fair warning with a notice that the kit is “for experienced modelers only.” It certainly gave me some experience!
The kit has no alignment pins for the horizontal stabilizers, engine pylons, delta fins or winglets. The only available pins are for mounting the engines to the pylons. (A good thing too since the engines are mounted with the thrust reversers at an angle.) Most of the kits parts are molded on the sprues with their attaching surfaces to the sprues. As you sand the part you damage the parts shape and can create gaps when the parts are assembled.
There’s no cabin interior detail, so painting the cabin windows black seemed a good plan. I glued a piece of strip inside the fuselege halves as an extra surface to hold the windows. The clear windows were molded just a bit too small for the openings. They couldn’t fit flush and several dried crooked in their openings. The kit did supply extra cabin windows though.
The cockpit has decals for instruments, but windshield distortion renders the use worthless. Prefitting the single windscreen made me think there wouldn’t be much of a gap to overcome where the clear fuselege section mated to the rest of the plane. After assembly and painting though, the joint had a bigger gap. Attaching it prior to painting didn’t appeal to me. Sanding along the side windows would have removed the frame detail. Finishing the model though made me rethink it. If I had it to do over, I’d have mounted the clear piece and sanded it flush all around.
Initial painting went fine using Acryl acrylics. Masking for the bare metal leading edges started out OK but I pulled some paint from the wings and vertical stablizer afterwords. Repairing the paint damage didn’t go well. Then trying to mask the metal to repair the black, pulled the metal paint up too. But this wasn’t the kit’s fault.
The vertical stabilizer and the wings had gaps the required using stock strips to help fill. With no alignment pins for the delta fins, I added a stock strip underneath on each side to increase the gluing surface.
I didn’t go with the kit’s paint scheme but used the kit decals for some of the stripes and cabin window and door frames. The decals were very thin and difficult to keep square as the frames were a single decal each with no clear decal to fill the space between the frames. Each one seemed to prefer being a trapazoid shape instead of fitting around the cabin windows.
Antenna and small detail parts were not molded with the fuselege curve taken into account so they didn’t mount flush. Using a round file helped some, but trying to match the curve on the small and fragile parts was limited at best.
I bought some aftermarket slanted letters and numbers from Draw Decal for the registration numbers. My choice of letters reflects my disappointment with my work on the model.
Trying to build the kit again would yield better results, I’m sure, but it is a shame that commercial biz-jets aren’t seen by the major kit manufacturers as a viable market.
They are attractive aircraft.
