Ambroid EZ Mask (liquid)
I just bought this stuff thinking it might help make the job of masking the canopy of my Junkers Ju 88C-6. boy was I wrong. Have any of you ever used this stuff? Maybe I am not using this stuff correctly.
I had the same misfurtune as you with that stuff.
Basically, all I see that it is good for is to be used as a water-based temporary tacking glue.
It does not go on well, nor does it peel off that easily.
Tom T[C):-)]
I’ve found it’s best only for masking small areas that otherwise would be difficult or near impossible with masking tape, etc. I use a flat toothpick to remove it, or sometimes a squadron scriber.
Hello chaps
Well, I didn’t even know this stuff existed but I use Easy Mask from Micro Mark and you must use a thick coat for this thing to work properly ( taking a thin coat off will be a challenge) Did you try this way with your product ?
When I do use it, I usually slap it on pretty thick. I also have the MicroMark product, but haven’t tried it yet.
