This may well be my all time favorite build to follow!
Thanks TomZ! You do realize that at best you are watching the Moorish idol from “Finding Nemo” trying to plot an elaborate scheme, and at worst a blind person wandering through a minefield right?
Like Captain Jack Sparrow, I’m just making it up as I go along. [prte]
Seems only fair then, to watch as the thing comes together…unless there’s rum
tootles
Yes, just where IS the rum? Where did all the rum go? Oh… Hide the rum!
Work has been slower than desired due to non-modeling stuff getting in the way, but another coat of primer has gone on and I got some black paint on the wheels to start the coloring process. The Tamiya rattle can flat black probably wasn’t shaken enough prior to decanting, so it ended up semi-gloss. But it dried fast and hard like Tamiya sprays always do.
https://flic.kr/p/DzHeGV]
[/url]APC-71 by N.T. Izumi, on Flickr
While checking the turret for free movement (okay, I was playing around with it, you caught me!) I noticed the relocated brush guard interfered with the gun barrels. So some strip styrene was added to the inside of the guide rail tracks to keep the turret from sliding too far forward. I threw in some punched bolts and washers to add some visual interest to the makeshift fix.
https://flic.kr/p/DxyCBy]
[/url]APC-69 by N.T. Izumi, on Flickr
https://flic.kr/p/CLzFj6]
[/url]APC-70 by N.T. Izumi, on Flickr
I just need to go over the model one more time to check for flaws, and add the “teepee” thing on the roof. Anyone knows what this thing is supposed to be protecting? I watched Aliens over the weekend, and it appears to be either a periscope or a strobe light that strobes really slowly. Oh yeah, I still have to add rivets to the window frames. But after that - it’s time to paint!
She looks great G! I need to go back and rewatch the movie but she looks like I remember her.
[Y][Y] Superb detail work! [t$t]
Thanks for your continued support Gamera and Stik! I finally found my answer to the “teepee” mystery thanks to the Internet. Photo is for informational use only under fair use, etc. etc…
https://flic.kr/p/CNz4La]
[/url]APC-72 by N.T. Izumi, on Flickr
The bump guard is made from two bent rods welded together at the apex of the pyramid, and the thing it protects does look like a white light of some kind. That’s my story, and I’m sticking to it! They will be easy to make. (Note to self: Finish these last little details this week and prep for painting so as not to keep everyone waiting!)
Sgt Apone: “All right sweethearts you heard the man and you know the drill, a**holes and elbows, let’s move!!!”
Like Cornholio, the toilet paper craving messiah, I now have teepee for my bunghole -er - APC!
0.015" plastic rod was bent using heat from a lighted incense stick to form the guard. A sliver of heat stretched plastic tube (just like sprue!) was cut to form the ring base for the light. Clear stretched sprue will be fed up from below to form the light (seen here push fit in place).
https://flic.kr/p/CPUEyy]
[/url]APC-73 by N.T. Izumi, on Flickr
Aw nuts, now do I have to put in a blinkie LED for the light? Oh well, I have to get some more lights for the Drop Ship anyway…
I think you have done very well [Y] …toilet paper? bunghole? LEaD lites?..I gets so confused [8-)] by SiFi stuff .
Super awesome detailing, I can’t wait to see more.
As Bevis would probably say, 'Burn out the Xenomorphs with fire, FIRE, FIRE!!!’
Looking forward to seeing some paint slapping on this monster!
"As Beavis would probably say, 'Burn out the Xenomorphs with fire, FIRE, FIRE!!!"
Uh, huh-huh. You’d better like, settle down Gamera. Huh-huh. Huh-huh. Huh-huh-huh-huh. Yeah, Colonial Marines kick butt.
[:P]
Window frame is now detailed with Archer rivet decals.
https://flic.kr/p/DQbcEf]
[/url]APC-74A by N.T. Izumi, on Flickr
https://flic.kr/p/CUiVx1]
[/url]APC-74 by N.T. Izumi, on Flickr
If you haven’t tried Archer rivets, you should! They are easy to apply and suck down with the usual decal setting solutions. Mr. Decal Softer, while a little strong, helped me skip the gloss coat and eliminate silvering over the flat primer. But milder Micro Sol was initially used. That little tidbit is kind of important in order to avoid destroying the decals!
Looking at the suspension, I realized that the inner hull was visible even when the wheels were in place, so so blanking plates were quickly fashioned to close off the line of sight through the hull. The kit plastic is around 0.050" thick at the wheel wells, but I used 0.040" sheet plastic, figuring that it is better to have an obvious mismatch rather than struggling to fair in the new with old.
https://flic.kr/p/DPv24d]
[/url]APC-75 by N.T. Izumi, on Flickr
https://flic.kr/p/DpHhqE]
[/url]APC-76 by N.T. Izumi, on Flickr
There will be a brief intermisison, due to my fat rear end knocking the model off a chair and onto the hard floor! The kit’s plastic is horrifyingly brittle, so bits of the turret rail shattered into small pieces, and one of the rear fenders broke off in a jagged mess. The turret got one of its guns knocked off, and a corner got chipped. The rail damage was caused by the metal pins in the turret base smashing through as the model pancaked upside down on the floor. At least the pins survived intact. I recovered most of the little shards, but one piece of the turret rail is MIA. I initially didn’t want to even look at the model after the accident, but after cleaning everything up, I set about gluing the bits back together. This is the rail with the missing shard.
https://flic.kr/p/CZgVFG]
[/url]APC-78 by N.T. Izumi, on Flickr
"When single is the triple sun
what was sundered and undone
shall be made whole, the two made one,
by scratchbuilt part or else by none!"
God, I wanted to screech “HAKSKEEKAAAAA!!!” and take a swing at something for doing something so stupid. Reminder to self: Do NOT put a model on a tool box that is known to be very slippery, while on a chair that is behind my butt.
Anyway, repairs are continuing and should be completed shortly.
Repairs from Saturday’s accident are almost done. A bit of 0.030" strip styrene was used to fill in the gap on the rail, after cutting away the jagged damaged section. A little more filling and some delicate sanding is all that is left to do.
https://flic.kr/p/E2NEuP]
[/url]APC-81 by N.T. Izumi, on Flickr
For some reason I was dilly-dallying getting to the belly hatch securing system. I had thought about using rare earth magnets, so instead of going to bed like a good little boy, I set about getting it done. The magnets are encapsulated with short plastic tubing segments and 0.015" sheet plastic caps. They were in turn glued to the belly hatch and in matching locations on triangular plastic plates fixed inside the hull. A lot of peeking and prying was needed to get everything to match up, but it is done!
https://flic.kr/p/DzGaph]
[/url]APC-82 by N.T. Izumi, on Flickr
https://flic.kr/p/Dtjupk]
[/url]APC-83 by N.T. Izumi, on Flickr
The magnet force is neither too strong nor too weak, so I am satisfied. To remove the plate, I will drill out two holes where some raised rim detail is, and use a bent paper clip to reach in and pull the hatch free.
Last item on the to-do list is to make some new headlight reflectors, as I am unhappy about the way my setup looks at the moment.
Great to see things back on track. I think the last time I dropped a model I stuffed it back in the box and walked away for over a year.
Very clever idea there on the battery compartment!
Thanks Gamera! I am hoping to re-prime the damaged sections and begin pre-shading this week and start painting proper next week.
I have seen people make swappable parts using hidden magnets, as well as figures that stand using them. I also have some 12" collectible action figures that use magnets to hold optional parts and conceal battery access compartments, so the idea was cribbed from those sources.
I’ll do the same for the Drop Ship loading ramp (to access batteries, not to deploy a 1/72 APC). I keep telling myself that over and over. BTW, the Drop Ship can’t be 1/72 because I already checked the relative size of a 1/72 APC based on the 1/35 kit, and it will NOT fit in the bay. Yes, yes, I already said no APC…
i like what you’ve been doing to this
Thanks Octane Orange! Painting will commence shortly, as I was able to pre-shade the model over the weekend. It looks kind of toasted right now, as I just hosed down some black on all the corners and stuff. Pics tomorrow as I’m too stupid to do it from my phone.
Oh yeah, I’d better have a dig through the paint box to pick a color! The real vehicle looked OD to me.
