My Albatros DV 1917 1/72 Airfix… I hope you like …
Like ? There’s no like, I LOVE this little plane and the job you’ve done on it !
How do you get the top wing aligned so perfectly ? I have temporarily shelved a double winger I am working on because of this reason.
I just don’t understand how you 1/72 builders can make these little kits look so much larger than they are. Simply fabulous work there. Very cool.
hello jay jay is easy after painting the wings of the model carefully rub the supeficie with black carbon paper of office and walla =) perfectly aligned not forget to apply the varnish matte charcoal q is not clear … … Greetings from Venezuela
Thanks BrandonK
You did good on that ancient kit, much better than I ever did. How did you paint the prop?
Outstanding!
Hello!
At first I didn’t like how the green on the wing looks uneven, but then, seeing the next photos I have to say the model looks really good and consistent. Congratulations! Good luck with your next builds and have a nice day
Paweł
Welcome, Ronald!
Very nice work on a challenging old kit. As Pawel said, you did a great job of making your finish consistent overall (which is often harder than it looks).
Please show us more of your work when you get the chance.
That is absolutely beautiful, you took a small scale and blew it up proportionally with skills.
Toshi
Hola chicos me alegro de que te gustaba mi trabajo Que Carece de Recordar Una pieza en el juego, Asi Que Tuve Que jugar con cianokrilato Trabajo duro era Porque el plano posterior de la aeronave. Aquí os dejo ALGUNAS Imágenes de la obra de la Reproducción de la pieza. Saludos …
Hola Ronald!
Mi Español no es muy bien, tambien una pregunte en Ingles:
How much time did the superglue take to set completely? Did you have much sanding afterwards?
Que tengas un buen día
Paweł
Its easy, we put a magnifier on our camera’s. [;)]
Nice work on this. I know rigging a 72nd bi plane is not easy. That’s a good job there.
Wow! Very well done! I can’t imagine building something so small in 1/72 and having it look anywhere near as good.
-BD-
Thanks Friends
