Does any body know of any aftermarket upgrades for airfixs short sunderland because mine has distorted and scratched clear parts and is in need of some extra detail.
G’day stuka_69 have you tryed e-mailing airfix to see if they can replace the warped parts . And you can get replacement canopys from squadron and several PE update sets which you can get from WEM as well . there has been a bit of a descusion in if it float and flys group build check it out there are some great links to some great sites.
Replacment canopys can be ordered from squadron the short sutherland canopy astrodome and nose,dorsal,and the tail turret …stock number SQ9192…
WEM PE 7202 - Short Sunderland Exterior Detail Set:
Contains: Outer Wing Float Strut Rigging, Aft Cabin Roof Antennas, Under Wing Yagi Antenna Supports, Under Wing Yagi Antenna, Cockpit Roof Yagi Antenna, Pitot Static Probe, Aft Cabin Side Antennas, Cockpit Roof Yagi Support Mast.
WEM PE 7206 - Short Sunderland Cockpit Detail Set:
Contains: Main Floor, Stair Well, Lower Step, Upper Steps, Main Spar Bulkhead, Central Bulkhead, Map Pocket, Pistol Holster, Flight Instruments, Control Wheels, Instrument Panel, Sun Shield, Cockpit Floor Riser, Stair Well Extension, Pilots Seat Attachments, Rear Cabin Ladder, Rear Cabin Hatch, Shoulder Straps, Lap Straps, Mooring Foot Plate (Stbd), Mooring Foot Plate (Port), Bomb Aimers Floor Plate, Mooring Ladder, Bomb Aimers Window, Rear Cabin Bulkhead, Cockpit Stbd Side Frame, Cockpit Port Side Frame, Roof Console Assembly, Navigators Position Parts, Rudder Pedals, Throttle Quadrant Box, Pilots Seats, Pilots Seat Support Frames, Throttle Control Levers, Pitch Control Levers, Throttle Quadrant Guides, Wireless Operators Position Parts.
WEM PE 7207 - Short Sunderland Depth Charge Compartment Set:
Contains: Sloping Deck Section, Bomb Bay, Deck & Aft Bulkhead, Bomb Racks, Sway Braces, Bomb Rack Attachment Plate, Upper Access Hatch to Flight Deck, Bomb Bay Forward Bulkhead, Forward and Aft Access Doors.
Here’s a link to a awesome build , its been a great help too me . I don’t think that I will go that far with mine…the only problem that I have is that 2 blades have been broken of 2 of the props .
http://www.armorama.com/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=423
and found this at great model webstore …
I hope some of this helps.
cheers mike
There’s been a couple of build articles posted over at www.hyperscale.com based on the Airfix kit since the WEM photoetch sets came out for it. The builds are quite nice and prove that despite the age of the kit, it can still be a jaw dropper.
Wow I didn’t know that there was so much possible detail that could go into this kit thanks for the referance.
If anyone sles knows some good sights with reviews of this model can you please write in thanks?
