I’m building the Hasegawa 1/48 Bf109G-2, and was thinking about buying the Aires 4036 DB605 engine to add to the model. Does anyone know if the Aires kit comes with what’s needed to install the engine in the plane? If it doesn’t, how is the best way to install it?
Thanks!!
The kit only contain the engine but not the engine braces. in order to mount the engine you need the braces. I bought one now I’ve to find an aftermarket or scratchbuild. VP detail set might provide one at lower prices.
I bought engine for my bf in 1/32 and as it said cacu you get only engine. unfortunately 2 months later I find out that there is “engine set” ( i’m telling for 1/32) with engine, engine bed and all you need to mount engine …(even cannons are inside ) so try if there is engine set for 1/48
