I’m relatively new to the hobby and have never airbrushed camo before. I want to try an urban camo color scheme on a gundam model using masks. The gundam is mostly an off-white color, and the camo stripes will be dark grey and light grey, maybe a light blue.
Conventional wisdom is to do the masking from light colors to dark colors. But what do we do if the final layer color is much lighter than the stripes? Will I need to spray primer before the final color to cover up the dark grey?
Red, if I am reading you correctly,you may have the “masking order” mixed up
Here is the “painting order” that most would recommend,paint the Off White color first, then the Light Grey, the Light Blue, and then the Dark Grey
We paint from lightest to darkest, masking to preserve the light areas as we go along,leaving one last set of masks that have only the intended darkest areas open to the airbrush
Lets say I have a large piece that is predominantly white in color, and I want to paint light blue and medium grey camouflage patterns on it.
This was my plan –
Spray the piece in light blue first
Mask off the blue camo pattern that I want to keep using putty or tape.
Spray in medium grey
Mask off the grey areas that I want to keep.
Spray in white
Remove masks, which should then show the blue and grey patterns.
I’m not sure about step 5, i.e. how the white would look if I sprayed it over the grey from step 4.
Is this what you are suggesting?
Spray in white
Mask areas where I don’t want camo patterns
Spray in blue
Mask blue areas which I want to keep
Spray in grey
Remove masks
Step 2 seems to be a difficult step here. To mask off large patches of white seems counterintuitive compared to masking off the camo patterns in my original plan.
It would really depend on the size of the lighter colours. With some schemes, such as German aircraft with the wave pattern over them, you have to paint the light colour last. But these are thin stripes and you don’t mask those.
But in general the second method you posted would be the best way to proceed. Is it simply because the white is such a large area that you are concerned about masking it.
modelers are usually after the thinest accumulation of coats as possible, and it takes less paint to cover a light with a dark than it does to cover a dark with a light
