I have no idea what is going on with me lately. I own and regularly use 3 Iwata airbrushes - HP-CS, HP-CR, and HP-BH. The -CS was my go-to tool, but it quit spraying about a year ago. When the other two did likewise at virtually the same time, I sent the -CS and -BH in for service by Iwata.
When I got them back, they initially worked okay, although I felt like there was still an issue with each. They weren’t as smooth as they had been. And today, both quit spraying again. Now let me define what I mean by ‘quit spraying’ - they spray air just fine, just not paint or even solvent that I tried spraying as well.
Having just sent these in for service, which is not free - I believe I spent just short of $200 to get these two serviced, and I have yet to send in the -CR - I don’t believe I should have any issues with them now. I’ll get on a phone call with Iwata tomorrow and determine what options I have. I sent the -BH back at the end of February, the -CS a couple of weeks later, so we’re not talking about a lot of heavy usage to get back to this issue.
I am not beholden to any particular paint brand or type. I use acrylics, enamels, and lacquers on any given project. AK Interactive, Tamiya, Model Master, Mission Models, Vallejo, Gunze, Humbrol. I use thinners intended for each type of paint.
I pour in a little Tamiya airbrush cleaner between colors and at the end of every paint session to clean the paint cup thoroughly with a stiff brush, then spray that stuff to clear out anything on the needle or paint tip. When I’m done with a paint session, after the Tamiya airbrush cleaner, I disassemble the brush down to the gasket inside the brush and use a micro-brush soaked in lacquer thinner to scrub the inside. The paint nozzles are a bit more difficult - sometimes I will soak those in a bowl of lacquer thinner, other times I’ll use a fine paint brush soaked in lacquer thinner to ensure I can get the tip of the paint brush through the tiny opening in the nozzle, then use a dental brush soaked in lacquer thinner to clean the inside of the nozzle. I don’t always disassemble the air piston, but when I do, I clean that much like I do the main airbrush body and components. I always wipe the needle down with lacquer thinner.
When I’m done with that and know I will not be painting again for any given time, I will put a few drops of Badger needle juice on the needle to lube the insides.
So with this description of what I’m doing, does anyone see anything that I’m doing badly?
