Hi folks,
My airbrush is demonstrating a significantly wider spray pattern in the vertical axis than the horizontal axis. What could be causing this?
It’s my first airbrush, a cheapie from China that came with a compressor so I don’t have any personal experience to benchmark from. Thought I needed a smaller needle, but maybe I just need to spray up and down instead of side-to-side?
Edit: Probably poor needle alignment… I loosened the grip on the needle and rotated a couple of times. Now appears to perform as intended…
Thanks anyway!
