The compressor says it has a 1/8" NPT fitting (anyone know what NPT stands for?) but my airbrush (piece of crap that it is) has a 1/2" adapter (undoubtedly designed for Aztek/Testors compressors…not exactly sure on the size).
Does anyone know if someone makes a fitting that will enable me to use my airbrush with this compressor (my LHS should have it, right?) or am I going to have to get a new airbrush?
Heading to the LHS tonight, so your help is most appreciated. Thanks!
Added 08:40am:
I should note that the compressor came with an airhose which fits perfectly to the compressor, and has 2 different size adapters on it…one looks like 1/8" and the other like 1/4" (not exactly sure on those sizes, either).
NPT stands for National Pipe Thread, and it is a standard for tapered pipe threadings.
I can’t be sure looking at the picture of the compressor, but it looks like it already has a hose whose free end is the female side of a industrial standard “quick connect” hose coupler. I.e. the leftmost item in the picture at: http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=42444
If I’m right about this, you shouldn’t be concerned at all about the 1/8" NPT output of the compressor as that is already handled by the hose that comes with the comrepssor. What you need is to put the corresponding male connector on your airbrush hose end, I.e one of the four other items in the picture.
Since it is very possible that the end of the hose on your airbrush won’t directly match the 1/4" NPT thread on the male quick connect coupler, you’ll also need to get an adapter for to convert the airbrush hose end to the quick connect thread. I noticed in the description that the airbrush comes with a “compressor adapter”, so it might already have what you need. If not, a good hardware store will be able to help you get the right fitting.
Yeah, the hose that came with the compressor fits over a nipple on the compressor itself and is then tightened down with a brass fitting. So I’m happy with the compressor and it’s connections…just not my airbrush.
The “business end” of the compressor hose will accept either a 1/8" or 1/4" male attachment…unfortunately, my airbrush only has a 1/4" (?) female adapter…as if it’s supposed to screw directly to the compressor (must be an Aztek/Testors thing).
I was reading “Airbrush Roundup, Part 1” last night and this morning, and it looks like all the Aztek airbrushes come with their own hose permanently attached and require an adapter, but other airbrushes like Badger and Paasche have a 1/8" fitting right on the brush, so you can hook up to your compressor’s hose. For those of you who have those brushes, does that sound right?
I’d rather buy an adapter because it’s cheaper, but part of me is ticked off enough with my airbrush that I’m almost willing to drop the $ needed to buy a new one. My wife doesn’t care, she just wants me to be happy (she let me pick out hte compressor for my birthday). [:D]
My Paasche (and Now Iwata) all have a 1/4" NPT end on them. It screws right on to the compressor. Badger makes an adapter for thier hoses to fit 1/4 npt.
Most airbrush companies tend to use either 1/8" NPT or 1/4" NPT connections. The 1/8" connections are smaller and provide a more compact connection at the airbrush itself. 1/4" NPT is the unofficial standard for compressor connections. Go to a hardware store and get a compressor and odds are it is going to have a 1/4" NPT outlet on it. Higher capacity compressors may go to 3/8" or 1/2" but the garden-variety compressor is going to be 1/4" NPT.
Badger makes a fitting that goes form 1/8" NPT male to 1/4" NPT female for adapting their 1/8" hoses to 1/4" connections. I’m sure some of the other companies do as well.
As to what we think about Aztek airbrushes, it doesn’t really matter. What matters is what you think of it. The general consensus around here appears to be one of dislike, however there are several people who use them and get very good results from them. Personally, although I’ve never used one myself and am basing this on the recommendations around here, I wouldn’t trade any of my Badger brushes for a bucket of Azteks.
Sorry, I didn’t see that question. It is unlikely that a hardware store is going to have anything in 1/8" NPT however your LHS might since a lot of airbrushes use that size. Here is a link to the one that Badger makes: http://www.badgerairbrush.com/access2.htm
It is part no 50-023 and is about halfway down the page. I have seen these in hobby stores, but you may have to order it. Dixie Art (www.dixieart.com) has them and I think they are around $5.
Actually Hobby Lobby has the exact adapter made for your airbrush including a decent selection of nozzles. The adapter is less than ten bucks as well as each nozzle.
I had an Aztec double action and it was adequate, especially starting out. I didn’t want to make a big investment right away before I was sure I wanted to get back into modelling, plus I wanted something to learn on before I went bigtime. The nozzle that it came with was not the greatest for detail but Hobby Lobby had exactly what I needed with a .35 detail nozzle and a .40 med coverage nozzle. Like I said it was adequate and a cheap way to relearn.
I am not sure about the particular brush you have, but it looks to be more of a med coverage type brush and it doesn’t look like you can change the needle (nozzle for an Aztec). For 39.95 or so at Wal Mart they have a kit with an Aztec double action, about 16 flavors of acrylic, a pipette for drawing up paint etc, a neat hobby kiosk with room for all your paints, knives and a center compartment for putting your brushes in etc… (and a compressor adapter) With at least the detail nozzle listed above it is a decent first airbrush or an economical way to get into detailing…
