I have searched and I haven’t been able to find the pros and cons concerning different styles of airbrushes. I will be purchasing my first airbrush soon. Decided on a dual action type. I model mostly cars and the odd military model. Already have built a paint booth and purchased the compressor with a 3 gallon tank.
Which do you find better and why.
Internal mix vs external mix?
Gravity feed or bottom feed?
General purpose needle tip size? 0.3mm or 0.5mm or other
I like airbrushing, so I have several. I highly reccomend a .15 to .21 needle for fine work, including camo application. A .30 to .35 for general paint applications. If you’re going to have one needle, get a .30. Gravity feed, IMO, is the way to go. Go for a good quality brush, e.g. the Badger Velocity, Iwata or Harder & Steenbeck. Iwata has their Revolution series that are good buys for the money. Finally, as to the AB, go with a double action. Once you get use to using the trigger, you’ll find you have much more control over the paint application.
