Air hose extension
I would like to add an additional hose to my master airbrush pump. I’m not sure what kind of fixture I would need or extension nut or screw or whatever you wanna call it to add the additional hose onto the existing hose if I could get someone to give me a link so I can get those Joint or union to extend the hose, I’d appreciate it all I wanna do is make this hose longer, so I can use it in a different part of my shop without having to move my pump
I bought this set and found it to be helpful and good quality. Maybe it will have the coupler you need
https://www.amazon.com/SAGUD-Airbrush-Connector-Accessories-Compressor/dp/B091K4N7K4
Thanks I ordered them. Hope they work out. Appreciate the input
To me, it looks like this set only contains metric adapters. Some times the adapter needed is a British/US thread to metric adapter for US made compressors. Such adapters are availabe from good hardware stores. Forget the tread sizes.
I’ve used 1/4 inch brass pipes, nipples, and elbows obtained from the local big box hardware store to connect/extend my air supply from my compressor.
Works well, the only problem I’ve found is that they do not have a model manufacturer’s logo affixed.
