Advice on using water color pencils
I bought a set of water color pencils hoping to learn some weathering techniques but can’t seem to find any resources that show how to use them. I was able to find one youtube video comparing a couple types of pencils. Does anyone here use water colors?
Here is an excellent Youtube test by Will Pattison on that very subject. Enjoy Mate
https://www.youtube.com/watch?v=JmV0_s7DOnw&t=6s
Yes, that’s the video I mentioned above. It’s pretty much the only resource I could find on the subject.
I have not heradof anyone useing these in modelling, most seem to go with oil or enamel weathering products. I’m trying to think what you would use them for.
Never heard of using colored pencils. Chalks, yes - colored pencils, no. Curious on how they work though.
I’ve seen people use then for chipping, but after watching the video above again, I see that he was using a soft tip pencil (not water color) for that. I purchased the same water color set he was using. In the video he also showed some blending techniques for things line oil drips and aging. So, maybe it’s not necessarily water colors that were being used.
You can see one briefly being used for weathering on a Hellcat F6F-3 on YT HERE @ 19:24.
Thanks. I’m probably going to return the water color and get the soft core pencils. It seems I got the wrong set.
I’ve seen the watercolor pencils used on fiberglass fish mounts. The fish is sprayed with a primer, then given a brown wash to highlight the scales. The watercolor pencils are used to put color in specific areas to build up translucent color. Then more opaque colors are airbrushed on, followed by metalics and pearls, depending on the fish.
I have a set of the watercolor pencils (for fish!), and I fooled around with them a bit on an airplane for weathering and color variation. But I found the oil washes and pastels worked better for what I was trying to achieve.
I found this tutorial , he is a top quality modeler
https://www.youtube.com/watch?v=JfRcJLMSQj8
Yep I follow him as well. He’s got a lot of great tips. [:)]
I use colored pencils all the time for artwork, and sometimes for model weathering. They come in a lot of flavors these days. For weathering, I recommend Faber-Castell’s Polychromos pencils…they are oil based, rather than wax based (Prismacolor is wax based). You can smudge them with your finger, but they adhere pretty well. Wax pencils are softer, so they might smear easier, but might not be as durable. I’m sure both would work, though. I sometimes use colored pencils for exhaust or gunsmoke stains, or rust, when I want more controlled results than I can achieve with other media. I’ve tried using the silver pencil for highlighting rivets and panel edges, which also works, but I think drybrushing with paint produces better results.
Watercolor pencils are just what they sound like…watercolor pigment bound into pencil form. If you hit them with water, they behave just like watercolors. But that means you can easily wipe them away with a wet brush, so they are of limited usefulness.
I have, BTW, also used colored pencils to camouflage scratches in natural wood flooring, which works very well.
