I have an old diaphragm compressor with have an adapter that has a 0.4 inch diameter screw that goes into the compressor and a 0.5 inch diameter screw on the other side which, in turn, connect to another adapter that has a Badger airhose output. (Sounds complicated? I’m just getting started [:)] )
I bought a paasche regulator that has 0.5 inch adapters on both sides. It wouldn’t be a problem attaching the regulator, but there is a minor glitch: I just found out that the first adapter on my compressor is rusting from the inside… I need to change it, but where can I buy adapters like that??
Thank you for your help (and patience…)
Try Dixie Art or Paasche.
Thx4
(I kind of hoped, someone would come up and say Publix carried these…) ![]()
