I have a very generic question here for everyone. I’m new to armor modeling but have been modeling for many years in various subjects (fixed wing aircraft, F1/auto, rotary aircraft). I have read many posts that mention the use of Acrylic paints on armor kits. I have always been a big enamel painter and I am curious if there is a reason or reasons for the use of acrylics in this particular subject? Is it trends, ease of use, doesn’t really matter? I’m really getting into the armor kits and may make it my main subject of interest. I guess if there is something I’m missing by not using acrylic paints PLEASE let me know. I’m open to using any medium.
Thanks for everyone’s input!
Justin,
It is more a matter of preference I suppose. But here is why I use acrylics.
- Fast. I can spray a whole 3 color camo job in one day (less the weathering). It can be masked fairly quickly after spraying. I used silly putty to mask, it has little or no tack so there isn’t much chance of lifting the paint.
-Clean. Thin with water/alcohol/flow aid mix and your ready to go. I can flush out my airbrush between colors with tap water and be ready to go again.
-I can use oil washes over it without any chance of damaging the base colors. Also I can scratch up paint coats (weathering) easily because it isn’t as hard as enamel.
There is some concern that acrylics don’t airbrush as well, but using flow aid really helps this a lot. One thing to watch out for though is this… Testors Dullcoat and Glosscoat react badly with Tamiya paints. I haven’t had this problem with other acrylic paints. This is also outlined in an article in FSM from several years ago.
God Bless
Kenneth
I use acrylics (Tamiya) because of the kind of ‘clear’ I use. I use a lacquer ‘clear-coat’ that I started using while building car kits. Anyway, Tamiya acrylics are not bothered by the lacquer ‘clear-coat’. The two are compatible! Enamels would be another story. I also find acrylics seem to dry faster. Use whatever works for you.
Glenn
Speaking very relatively, acrylics (depending on manufacturer and thinners used) can be safer to use than enamels. The solvents aren’t quite as volatile; therefore, the potential for overexposures to solvent vapors via inhalation is reduced. However, the use of isopropyl or methy alcohol-based thinners raises the risk substantially. Acrylics may also potentially reduce the risk of fire. Once again, the choice of thinner material may increase that risk as well.
Gip Winecoff
After being a DIE HARD enamel user for years, I made the switch to acrylics. (Tamiya to be specific) I can get better flow and results with them, in my airbrush. Not to mention, cleanup is sooooo much easier.
The only thing is, with the tendency acrylics have to dry rather quickly, I still use Testor’s Model Master enamels for weathering and drybrushing. Enamels give me a longer working time.
Not much to add except that I prefer airbrushing Acrylics and brushing on enamels. my [2c]
I’ve been a diehard Tamiya Acrylic fan for a number of years. Mostly because I don’t like the clean-up of enamels.
I use both, but I tend to use Model Master acrylics more. I’m a little lazy and clean up is much easier. LIke Eric said though, brushing with enamels is easier.
As I have nowhere to use an airbrush I tend to stick to Humbrol enamels as I’ve never had any success brushing Tamiya acrylics.
Regards
Pete
jmixon as you can see it is realy a matter of personal choice whether you use acrylics or enamels. I have used both for airbrushing but usually use enamels for brushing but I am in the process of converting to using Vallejo Acrylics.
One big advantage of acrylics is the after painting clean up. On thing I did learn about brushing with Tamiya Acrylics is that you have to let then not only to dry between coats but allow the acrylic to cure -[|)] this can take up to 72 hours[|)] failure to do this will cause the previous coat to disovle as you are brushing.
Thanks for everyones input.
I did use some MM acrylics this weekend and had great results considering its my first time using them. I didn’t have to thin and cleanup was a snap. I did have a little spatter or overspray with them but nothing to be worried about. I believe if I thinned them out a little bit that would help quite a bit. I was actually using a wide spray needle in my brush so that could have contributed a little.
Needless to say I think Im hooked. Another good thing I noticed at least here locally is that they are a little cheaper than enamel paints. Not much but any savings is better than none!.
Thanks for the input South Aussie…I did notice that happen this weekend. I preshaded with black then waited about 15 min then sprayed a base color and it all blended together on the particular piece I was painting. Actually I got lucky and it made the color more what I wanted but this is very good information.
I think acrylic paints win for most applications . However, they may take a few weeks to cure 100%. They’re fine to the touch and recoating in less than an hour but don’t touch with bare hands! Put on thin white cotton gloves, fingers will leave nasty greasy prints, esp. visible on matte surfaces.
[#welcome]
(<-the only artifact I still need for the Unlimited Set btw.)
Hello fellow trekkie did we scare you off or did another one of your inter voices gain control and back out? We’re all crazy and all are wecomed.The Chase is probably one of the funiest episodes of TNG. “It could just be a recipe for biscuits for all we know,“Gul Macet. Naduq” In that case I’ll send you my mother’s” Just jump in.
It sems that all the airbrush users prefer acrylics but if you are brush painting you will find that enamels give much better coverage, especially the lighter shades.
I almost made the switch to acrylic today, but while I was at the hobby store looking at paint I noticed that it seemed sickly compared to the same brand enamel. The color was model master medium green. I didnt stir the paint but opened the lid on both and it didnt seem like they were the same color. I showed the employee and asking him to verify, and his response seemed to be thats the way it is. Anyone else seem to notice this or just bad batch/mismarked?
Replying to 9x19mm - comparing enamels to acrylics, unshaken, in the bottle, is like comparing apples to oranges. The chemistry of the two is different. The pigment in acrylic paint will almost entirely settle out after sitting. If you look at the pigment in the bottom of an acrylic paint, medium green, for instance, the pigment is a very dark green and the diluent or liquid, is a blue color. So you cannot compare the two until a coat of the paint has been laid and completely dried. You are better off comparing the color chips on the paint racks in the store.
BUILD TO LIVE, LIVE TO BUILD!
ENAMEL
[img=left]http://www.geocities.com/veritasps02/f86f-paf.jpg[/img=left]
vote—
http://www.hbo.com/boxing/games/
for Mr.Pacquiao!
I have yet to try acrylics on plastic models and have only used Model Master enamels thus far. I am going to try acrylics to see if I like them soon as spraying enamels in the garage with no paint booth is a pain.
The only negative about acrylics, at least all of the ones I have used or heard of, is their inability to take masking without an overcoat of clear. Acrylics by nature do not have a chemical that will etch the plastic and provide good adhesion as you get with paints like lacquers, urethanes and enamels. This is why automotive airbrush artists use mainly urethanes as their adhesion is fantastic. They are chosen for durability also which would not be a factor for a plastic model paint job, unless you plan on leaving it out in the rain. [:D]
Depends what I’m doing. Acrylics for figures, landscape etc because they dry fast, are easy to blend, mix and shade.
I use enamels for ‘hardware’ for exactly the same reason. Enamel colours tend to be stronger an more vivid and don’t seem to be as ‘organic’ as acrylics.
