Acrylic drybrushing problem
Hi everyone.
I am painting a vinyl character model (a recast of the Screamin’ 1/4 Pinhead - cheap and good practice), and am having some difficulty in drybrushing. I am using Tamiya acrylics, and have tried a couple of different types of brushes, but the paint keeps flaking and little flakes of white paint are sticking to my black base coat. These are not coming off even with some force, even though the paint on my brush is pretty dry, and are generally making a mess of my model. I don’t recall having this problem with my old enamel paint jobs - not that I have had much experience with either medium.
If anyone can give me any advice, I would be very grateful.
You might want to keep a small dish of Tamyia acrylic thinner out while your painting, just dipping the brush into every now and then.
This will stop the paint drying too quickly and flaking. I had similar problems with Gunze acrylics when i first tried dry brushing with them, but this seems to cure it.
Hope it helps.
karl
From my own experiances I’ve found that enamel paints are some what easier to dry brush with!
Maybe you should go back to using them??
ditto on Stuka’s comment. for myself Acrylics presented too much of a barrier in drybrushing so I bought a few of the basic colors (brown, black, silver, gray etc…) to drybrush with.
Karl (KJ200) does great work, so try his way and see if it works for you. I was too lazy and took the easy way out haha…
Good luck!
Oh yeah — I had better luck drybrushing MM acryl than Tamiya… tamiya seemed either to flake like you said or “gob” up in places and look ugly…
I used to ahve the same problem, but I went to my local art store and got a product that retards the drying time of acrylics, but doesn’t thin them in any way.
The person at the counter said it was a reducer that is commonly used with water painters.
Haven’t had a problem since[:D]
Thanks everyone, you’re right, I think I’ll grab some enamels for drybrushing in the future.
how about lacquers? have you guys ever used lacquers for drybrushing?
I have had good luck with Vallejo acrylics, they have a very large line of paint and they dry to a very flat finish.
I’ve been using a product by Liquitex, labeled “Slow-dry Fluid Retarder.” I had the same problem as mentioned with Tamiya; paint drying on the brush often before application and the paint generally drying up on the palette. Using the fluid retarder, I simply add 1 to 2 drops of it directly into the Tamiya paint and mix it in. The paint dries very, slowly and remains workable like enamels. For airbrushing, I often add a small amount to the mix to prevent tip drying during paint sessions. Liquitex Fluid Retarder is available at most local Micheals Art/Hobby stores and art suppliy shops. In my area, it sells for around $3.00 for a 2 oz…bottle. Check it out at their website: www.liquitex.com.
