Ok I’ve used all sorts of lacquer and enamel clears but what do I use over my tamiya acrylics if I airbrush a car body? They are a little glossy but not enough. Future? Ideas, suggestions?? Thanks in advance.
You could also use your Lacquer and Enamel clears over Tamiya without a problem if you allow enough time to cure.You could also use Future as you state.
You could also use Tamiya X-22 Gloss clear
I use Future or Tamiya gloss clear.
There are a number of brands of spray paint that have clear acrylic gloss, as well as acrylic clear matt and semi-gloss. Krylon is one brand with acrylic clears.
