Howdy. This is my first entry in the forum in several years, but I’ve enjoyed tremendously the models all of y’all have built, and I’ve learned a lot from y’all.
I guess I’m the dissenter on Academy. I just finished their 72nd scale B-17F, and a few months go finished their 32nd scale Sopwith Camel. Worst kits I’ve ever tried to build. They were for clients, and if I’d known when I started what I know now, I’d have never chosen those kits. Surface detail isn’t bad, but the fit was atrocious. On the Camel, there were no holes for the landing gear struts, and the holes for the cabin struts were at the wrong angle. I had to fill and re-drill them to get the struts on. If you cut the fuselage in section, you’d see that the lower surface was concave; it took hours to fill and sand it. The plastic is soft enough that if you use anything but the finer sanding sticks you’ll just gouge it, and it doesn’t glue worth a flip. I tried several styrene glues, superglue, Elmer’s, and a light epoxy. The super glue worked best, but not well.
On the B-17, again surface detail was okay, but the fit of the wings and stabilizers was awful. I had the same glue problems, and when I sat the finished model on its landing gear, the tail wheel strut just folded up! The clear parts were worse than on my Aurora Famous Fighters kits. The instructions were abysmal, especially on the Camel, which was designed by a demented tailor, anyway.
And those decals! Whew! Another writer talked about them, and I agree. I put the decals on the Camel - applied them over gloss laquer, dabbed some Micro Sol on them, and set them aside for the night. When I got up the next morning, the bloody things were laying on the table top under the model!
Oh, and on the B-17, I used the Legends detail set, and found it to be 'way out of scale. The detail was exquisite, but most of it didn’t fit worth a hoot.
Academy does some wonderful subjects, but I don’t know if I’ll ever buy another one.
