I am building this model, and I’m about to glue in the cockpit/engine pod (or whatever you call it[:)]). However, I have test-fitted it twice, and I noticed that the bottom of the cockpit floor will be partially visible through the lower side nose windows when everythign is glued in. Is this normal, or do I need to fix it with sheet styrene or something?
I havent built the kit, but I looked at the sprues online, and it looks like you need to fill the area below the floor with styrene sheet. I m still looking for a shot on the web to post but… no luck. Lemme know if you have any other questions
DDRmaniac,
Here’s what it should look like through the front lower bubble. This is a photo of an MH-60L which is what the AH-60L configuration is based on.[:D]
Thx for the pic. That helped a lot!
