Hi,
Yesterday a thought crossed my mind that made me wonder whay I hadn’t though of it much sooner.
Basically, several years ago I bought a copy of the 1/350 of Trumpeter’s LCS1 model. I knew that the kit had some accuracy issues, but all I really wanted was the decals and miscellaneous fittings for a 3D printed model of the new US Navy Frigate that I bought from Shapeways. It turns out that buying the full Trumpeter kit was less expenive for me than trying to buy separate 1/350 scale helos, guns, missiles, photo etch and flight deck decals. Anyway that Frigate model is currently on hold, but I was left with the (incorrectly shaped for the LCS) unused Trumpeter hull and superstructure that I didn’t have a use for.
[Mark Up of Trumpter LCS Figure showing shape issue]
[Partially Complete 1/350 Scale FFG(X) from Shapeways]
More recently (last year) I got messing around with my new 3D printer and 3D CAD, and tried my hand at making a notional “What-If” fire support vehicle model suitable for use by the USMC, since they had decided to get rid all of their heavy armor. In general the vehicle is meant to be kind of like the US Army’s Mobile Protected Firepower vehicle but with some potentail amphibious capability (see the image below for an early mock up that I did, with a Cockerill Turret that I found on the Interenet).
[Partial Build of a 3D Printed What-If Amphibious Fire Support Vehicle with a Cockerill Turret]
Anyway, while looking up information on potential USMC future missions that might require a direct and/or in-direct fire support vehicle, as well as information on some of the new artifical islands that China has been building in the Pacific, I came across a proposal from some country for an alternate idea where a tank turrt was fitted to a boat hull to provide near-offshore fire support (as shown below), which also sounded kind of like an interesting idea.
[Boat with Tank Turret - from Wikipedia]
Antasena-class combat boat - Wikipedia
For some reason though the thought never crossed my mind to maybe take my spare 1/350 scale misshapen LCS hull and use it instead as a basis for a 1/72 scale “Near Shore Fire Support Vessel”. If I have done the math correctly, the 1/350 scale hull of the 387.6ft long LCS1 should scale to about 79.75ft in 1/72 scale.
I’m not fully sure yet whether I should fit a normal Tank turret, with a conventional tank gun onboard the vessel, or maybe go a slightly different path. In researching stuff for the vehicle model that I mentioned above I read somewhere that some 90mm guns and vehicle turrets can be configured for both “direct fire” using standard tank rounds, or that the can also engage in “in-direct fire” like a Howitzer. In addition, there is some Eastern European country that has also developed a barrel launched anti-tank missile that can be fired from standard 90mm or 105mm tank type guns.
An additional though we also be to maybe augment the main “tank type” turret with a second mount aft on the ship capable of firing maybe a 20-40mm type high rpm cannon for instances where a high volume of fire may be of more use than a heavy round.
[Possible Twin 30mm AA Turret for also Mounting on Vessel - from Wikipedia]
Anyway, although I am currently busy with a group build airplane model right now, I may keep playing around with this idea and try and see what I eventually come up with. Maybe if all goes well I can start actually trying to “kitbash” the build in a month or so.
Pat [:)]
