A Nutty Idea
Hi ;
Listen , I found out something this past week . C.A. Affects LEGO like regular Tamiya liquid glue affects styrene ! This means that we as modelers can catch some at flea markets and do this .
Say you have a large ship .You don’t want to use the flimsy stand supplied to build that ship . Well , build a cradle of assorted LEGOS . You can Tailor it to fit the hull and Bingo ! there you go . Oh, It works for Armor and Aircraft too .
Talk about not seeing the forest for the trees .I’ve been doing this for years with cars !
The beautiful part . Once put together you have to build new , if the ship or armor , or plane and car is grossly different . You will still have the base rigs for everything else . It takes two pair of pliers to pull them apart once glued , and you’ll likely suffer irrepairable damage to the bricks . So just build new , Label them and put them in a drawer , for when you need them . T.B.
I bet those Legos can make a terrific Dry Dock for larger scales.
And Thanks T.B., I always watch for your posts.
Jim.
Jim;
Funny you should mention that ! I actually never thought of that ! Hmmmm , I guess I’ll have to see what I can do .Thanks . T.B.
I cleaned up my basement after the Grandkids were over and sorted all the un-built Legos into the proper boxes. Looks like there are a few hundred that Don’t Belong… So, I appropriated a few and will experiment. First thing to try is what do I have to do to get paint to really stick. These Logos are very Glossy. Guess I could sand a few hundred down but then I’ll never get to my Stash. Another thing is to determine what scale model ship will look appropriate either Mounted on some Legos or in a Diorama using Legos. What a dilema…
A neat Idea for something completly different. It may not be Museum quality but when I broached the idea to my oldest Grandson, He glowed! (He loves Legos!)
Jim.
Hi Jim !
Hey here’s an idea . LEGOS take paint well Especially Krylon Or Rustoleum Brand . Build a drydock Dio . It can be small or large . Remember ! According to " Rulers of the World " They work out to 1/20 scale ! That’s large ! By The Way I got a " Rulers of the World " comparison chart because of the Rail-Road Museum . T.B.
Well, I am a Rattle-Can sort-a Guy since I’m inexperienced with Airbrush. Krylon and Rustoleum are easy for me to get .
Looks like Legos could be used at various scales based on some Pics I broused. Maybe 1/144 or larger might work.Some of these Drydocks show really large wall sections.
Here’s a few…
http://ussconstitutionmuseum.org/wp-content/uploads/2015/05/FullSizeRender33.jpg
https://defencyclopedia.files.wordpress.com/2014/05/wpid-091019-n-2638r-002.jpg
http://www.crandalldrydock.com/Crandall%20pix/halifax_floating.jpg
One Man’s Legos could be another Mans inexpensive Floating Drydock Diorama
Hi ;
Oh you are on the right track . Now remember for smaller scale you use what LEGO calls plates . These are a third the height of the regular brick .Then you cover the studs with the flat 1x2, 1x3 etc tiles .This covers the studs . OR , Cut the visible studs off with a sprue cutter and glue .010 strips on to cover what you’ve done .
As far as paint sticking . Sand lightly with 320 grit WET after gluing , or wash with lacquer thinner ! .
Okay, just for fun…
Last Christmas the Grandkids were over and wanted to “build a wall”. (Too much tv?).
They built it and I found it on a shelf and did the natural thing, added to it. And then…
I had to put a model in it. And then… I remembered your “Nutty idea”. And then…
well, here we are, dry-docked at last.
Ran out of Legos.
The model is the Revell Snap-tite Nautilus. I added some left-over stuff. It is not finished. I am not doing a dry-dock Diorama. My granddaughter just wants the ship. A lot of touch-up is still needed. The figures were just for scale.
It’s a nice kit and since it’s fictitious, you can do anything you want with it. And yes, the wires go to internal lighting.
If I get another kit, I plan to completly reverse the plan. The Stern will become the Bow and the bottom will become the deck. The resulting profile seems to look more believable.
Nino
TB,
My wife has a great sense of Humor (She has to.). Late last night she saw my “drydock” and not knowing what it was supposed to be and knowing I played with it, made the appropriate comments. I saw it this morning on my way to the post office and grabbed some pics before they " …tear down this wall".
My “drydock” has been re-purposed.
Jim.
Oy Vay !
Now that’s a proof of what we always say . Keep an eye out for constructive / destructive cats at night .
Nino ;
I just re - read this post to see if I could add anything new . I have that very Submarine . One difference though . All the interior stuff have been replaced with scratch - Built plastic and brass components .
What a great cheap venue for detailing experiments . I went and bought two more to experiment with .
TB,
It is a fabulous model to play with.
Try making the Stern the Bow. Those “window” depressions no longer will imped forward movement. And then turn it upside down. All of a sudden it starts to look a bit like the USS Holland (Okay, wishful thinking : You need to narrow the hull A LOT lot and sand the hull smoth and add a fairwater and reshape the bow and stern. Fortunatly it would only need a simpler propeller setup).
The best part is you can make it any scale you want. It will work as a 1/48 Holland type sub or as a 1/200 20,000 leagues make believe sub which could scale out to 178 feet long- like the Disney/ Julkes Verne 20,000 leagues sub, depending a bit on how big you make the Ram.
I will PM you in prep to send you my original proposed WIP.
(I have no guts to post it)
I am in Virginia today with my grandkids. It would take awhile for me to access my WIP data in Philly. I will send it when I can.
Gonna watch all the Star Wars. The second oldest won every movie in a raffle including Rogue 1 and Last Jedi. I can sleep when I get home.
Jim.
Hmmm, Grandkids and Movies ;
Gotta love them . I got your W.I.P. ! Hey , stop that "I’m Chicken " stuff ! That is great !
Promise not to laugh ? I have even bought a fourth to turn it into a"Steam-Punk Airship "
Also this unit is great for a different type of “Space Vessel .”
I’m not laughing. I am smiling, Ear-to-ear. We think alike.
Gosh, I bought a “Lot” of 3 of’em a couple of months back and I have the one I just narrowed the hull on and I still have 1 un-built somewhere in the stash.
A space ship looms in the Future for sure.
Might make a nice Interplanetary Refueling Tanker. It’s wide enough.
And Thank you for reviewing my small wip “test”.
Jim.
Psst… I have another write up on a re-evaluation of the kit.
You are right, there’s plenty of possibilities for this nutty model.
Looking at it ;
have you considered taking the " Window " and putting it behind a door ? You know , like a torpedo Tube Door ? For the Steam - Punk version it will become the container for the steam engine and the flotation chemical . Plus the four bladed stick prop out back . Below will be a gondola reminiscent of an upside down Volkswagen Bus !
Now the other thing is take two , Cut them just right and make it longer . Even longer still with framing and sheet in the gap . Long enough that you can squeeze the ends and create the very neat Hunley ! Also a quarter of it makes a neat racing Hull Capsule for a " Star Wars" type Water-Borne Pod Racer . Shall I continue ?
Oh Yeah! Keep it going.
I was concerned that some of the folks might not follow our “mind-set” in the earlier posts so here are a few early trials on another Revell kit.
Narrowed.
Some ideas:
What-if. (Upside down and Bow and Stern reversed.)
Some “ideas” taped on.
How’bout that “caterpillar” engine in the hull recess? (It’s a green marker)
And one Lego pic in keeping with the spirit of the Thread. It’s reversed, just like my Sub above.
I will be sending you another “Document”, made during the Winter Doldrums. It’s based on the Revell Snap-tite Nautilus kit too.
Jim.
Hi Jim ;
I have that very LEGO kit !
I modified it though . Now the crane moves easily up and down the pier on little wheel sets . I did a Non - LEGO thing though . I took that hull and cut it in half . I then took another and cut the bow and stern off and inserted that large center piece , into that space on the other one .
Using the" LEGO " Plates to re-create the Deckhouse and deck hardware . That way I had everything in scale sort - of . One plate equals one third of a LEGO block in heighth . I converted the re-assembled hull into a MEGA -Tanker for my room . The Pier is longer and thanks to you I’ll have to have a Dry-Dock now ! LOL.LOL. T.B.
