5-ton wrecker kit
I am looking for a 1/35 US ARMY 5-Ton Wrecker kit that was made by either Revell or Tester in the 70-80’s. Also looking for a source for a resin kit to modify a M60 to an bridgelayer. I am interested in combat engineering vehicles, since I used to work on them.
Hmm you can try E-bay for the wrecker… I know Hobby Fan makes a modification kit for the Italeri 5-ton truck kit. But it runs about 180.00$, also they make the M9 ACER armored dozer. As far as the bridge layer I’m not sure. Maybe the Tank work shop or Accurate Armour.
Tnker101[}:)]
Thanks tnker101, I’ll look up the Hobby fan kit, but I think the Italeri kit is of a new 5-ton truck. Maybe I can back date the kit. THe new trucks have single tires on the rear axles and the older M800 series had doolies in the back. I labored for years on and off to build a CEV and now I see that there are two kits on the market, Atleast I can say I made it instead of I built it.
Real Models has a full kit resin M-62 wrecker. It may be out of production now. Hobby Fan has/had a full kit M-48 AVLB, very expensive.
Accurate Armor did the WLF version at about $250.00
Real models also makes a conversion kit to go with Italeri’s bigfoot 5t 6x6. it goes for about $90 at the hobby shop by me
This kit was originally released by Renwal and was based on the old M54 series 5 ton. Revell reissued it in the early 80s as the Military Wrecker. Very crude kit with over sized parts made to operate. I had one, and it wasn’t too bad. The kit was actually 1/32 scale.
The Italeri kit does represent the new 900 series 5 ton. There are two different wheel styles, the 10-wheel with the dual axles and the 6-wheel with the single tires. So an M936 wrecker has 10 wheels and an M936A2 has 6 wheels.
There’s also an older M816 wrecker that has 10 wheels as well. I have photos of the M816, M936, M936A2 and the newest FMTV M1078 5 ton wrecker in my motor pool.
Hey! I’m all for an M-62 kit, I spent 1 1/2 years behind the wheel of one in Germany a generation ago. AFV should make an M54 kit to go with their Viet Nam stuff. We could kit bash one into many configurations.
I wish they would come out with a M936A2 kit . I was on one for 2 yrs in Korea . one that has the STIS on it
Is there a kit available in 1/35 of the FMTV M1078 5 ton wrecker? Or maybe even just an FMTV.
I hope you have some luck trying to find your wrecker.
mark956
