Well, the output needs to be compatible with the 3D printer, which is usually some form of 3D file like stl (stereolithography) or the like. The specific printer will have a number offormats from which it can accept files (and usually one preferred format).
Typically the source files need to be in a “solid” modeling format, like that output by SolidWorks, Inventor, or the like. (Those files may need manipulation into the preferred printer format, if theyare not directly accepted.)
The printer format matters, too.the deposition printers which work by melting a filament buildup in layers, which can make ugly striations in the finished model at the limits of printing. Or, you have to bias the print, byt tipping it in two axes so that very little of the model is parallel to the deposition plane
The resin printers which us UV light to solidify the resin are less prone to “ridging” but are not immune. They, too, can work better with the model on a bias.
However that brings us to another item, “bridging” and “supports.” Parts without base supports need some sort of support to be cast. This bridging is of fine material, but still has to be cleaned off the finished parts, which can be difficult as those parts near the dimensions of the supoorts. (A plastic kit analogy would be “flash.” )
What all that measn is that, at a certain point, you may need to build up the 3d print from parts for final assembly.
So, this stuff is complicated. The current industry rus on hugely expensive printers in very short runs. The models are very niche in that they tend to be very soecific, which wi why very few are available in a resellers market.
Let’s say I wanted to stockpile Fleter Square bridges in my shop. Which scale? 1/700, 1/350, 1/150, 1/144, 1/96, or 1/72? My price is going to be the same as your price from Shapeways, so, to make a profit, to pay it’s way on my self, I have to charge more than the price you can pay online. So, no sale. I’m not coning to commit to a run of a hundred of these things, to, perhaps get a 5% knock off in price. Hobby stuff, especially accessories wants about a 50% markup as it moty sits on shelves getting dusty, that’s assuming I can afford to buy 100 unites at $120 each
Hopefully our member ModelMonkey, who is in the 3d print biz can weigh in here.
