1971 Plymouth Roadrunner 440+6
My new project is converting the Fast & Furious Dom’s '71 GTX into a '71 Roadrunner. I plan on a 440 powered, 3-speed automatic shifting, bench seat car painted with Testors Green Go aka Sassy Grass Green with a black interior. I plan on using a bench seat from my parts box, column mounted automatic shifter, and the kit wheels and wide tires from Dom’s GTX. Let’s see what I can do with this…
More Plymouth to come…
That should be eye catching!
I hope so, John! I’m going to be trying some new things with this build and I hope to do a good job on them!
I have never done this before. I’m changing the seat pattern on a Jo-Han bench seat from a long departed '68 Plymouth Fury Patrol Car. The Fury seat has no pattern to it at all and cutting up the bucket seats to get the GTX pattern only took a few minutes. So now I have to get the seat patterns down to the size of the Fury seat. I saved the head rests and will cut them down for the Fury seat. I drew a line on the center of the seat back so I can slice it into two seat backs for a 2-door.
Using my Dremel, I hollowed out the seating surfaces to the new inserts. I added the new seating surfaces and filled the edges with Bondo Glazing & Spot Putty. I’ll sand this when the putty has set and dried.
I fitted a piece of sheet styrene to the interior, but more sanding will be required. The plastic interior tub is much thicker than the sheet styrene I’m using and the seat will need to be raised slightly so it doesn’t rock back and forth. My patch will need to be blended into the tub further.
Looks good, are these new tooled kits or reissues of older ones?
Rob, this is just a re-issue of an older Monogram kit that is owned by Revell.
I have been looking at the engine in this kit and it has a hole in the oil filter. I covered the hole with a piece of rounded styrene. The hole might not be seen once the model is assembled, but I know that the hole is there and covered. I have also been sanding the trunk lid to remove the mounts for the rear spoiler that I am not going to use.
I have been looking at Sassy Grass Green '71 Roadrunners on Google Images and pictures of Roadrunners with painted bumpers are starting to appeal to me. I have a '71 GTX and a '71 Satellite on the shelf with chromed bumpers and painting the bumpers will give me a different “Fuselage” body style. I clipped the front and rear bumpers from the chrome sprue and covered them with Easy-Off Oven Cleaner and the chrome disappeared in 10 minutes. Now to paint them and the rest of the body parts!
I sprayed the chassis and the interior bottom with Tamiya Grey Surface Primer and the body, hood, engine, valances and exhaust system with Tamiya White Surface Primer. I decided to leave the front and rear bumpers in oven cleaner a while longer to be sure that all of the plating and undercoat was removed. They have been removed from the cleaner and washed and will be primered when they are dry.
I have spent the last two days (a few minutes here and there) removing the GTX from the grille. The GTX scripts where removed from the body rather easily, but I wasn’t sure if I wanted to attempt removing the script from the grille. I used a No. 11 blade, an angle blade and a pick to remove the scripts. It’s not perfect, but it does look decent and it will be painted flat black. The wheels have been cleaned and now to painted them with Alclad II Gloss Black Base followed by Alclad II Chrome. Then to paint the wheel centers with Tamiya TS-29 Semi Gloss Black.
Knowing You:
You will do such a super job, Someone will ask for the Keys! My 1;1 scale Convertible is still in storage. It’s painted a Gorgeous Pearl Sapphire metallic, But the Auto Storage place starts it and circulates the fluids as agreed upon. She still looks like new too!
One more year and I’ll have to sell her or go get her and start driving her. She has a Dove Grey and Arctic White ( original Pattern) modified leather interior, 4Spd. 440 Sixpack! and an Aerheart Disc brake conversion kit all four wheels!
There’s a Chrysler Product Club here, I may sell her to one of those folks. The price is NON-Negotiable.
Looking good Mr.Mike. Can’t wait to see it in paint. Really like what you got going with the seats.
Thanks T-B and SickBoy!
I held off long enough and I started painting today. I painted the wheels with Alclad II Gloss Black and then I painted them with Alclad II Chrome with my Badger 150 airbrush. Then I painted and detailed the disc brakes. I spent some time on the bench seat and added headrests using the tops of the bucket seat headrests.
While the paintbooth was up and running, I painted a few more parts including the engine, front and rear bumpers and the body. I noticed some mold lines on the front fenders and I removed those and reprimered the body which produced a large paint run. I used a piece of paper towel to stop the run and in the back of my mind I heard, “Don’t!”, but it was too late and I made a mess out of the primer. I’ll sand the primer and then I’ll paint the body later.
Coming along nicely Mike! Keep up the good work.
Jim [cptn]
Stay Safe.
Didja Know?
That shade of Green can be found on Money? Yup, Guess that’s why I like it!
Okay. Thanks Jim and T-B!
I finished the chassis this afternoon. I found a set of extended shocks from the Revell '68 Charger kit. I cut them down to fit and painted them red for contrast. The rear wheels and tires are a very tight fit!
This afternoon, I wired the engine, added exhaust manifolds, heater hoses and decals. I need to add an ignition coil. Then I painted the bench seat, steering column, radiator, dash and the body.
Didja Know?
Most Chrysler products of that year in Buffalo,N.Y. Rusted away alongside the drive shaft tunnel first? Then the footwells. Mine was a California car after being a Texas sell.
Okay. My question to you is…what does this have to do with my model or WIP?
Well, chock up another screw up to Revell. I went and looked at the decal sheet and the decals don’t fit the hood since they are a little on the short side. Then I looked at decal no. 6 and then I went to the instruction sheet and there is no mention of no. 6 decals or decals for the caliphers. I wonder what the decals and the instruction sheet for the Revell of Germany kit looks like. I heard that the decal sheet is bigger!
I painted the dash and the radiator. The radiator has be detailed and the dash is next.
