1945 GB
Eric…Great "Grandpa " story… I’ve heard (as a little boy) many similar stories from both sides, paternal were from Alabama/Georgia and maternal from Michigan, Both sides side moved to Detroit to work in the war plants of the time and that’s how my parents met. I remember my one Granddad telling of having to stop every 1 to 2 hundred miles to replace the packing in the water pump of his old Pontiac. Thank you for sharing your story, Too many of these great stories are being lost to time, and there are many times I wished that I had been able to somehow preserve these stories.
Andrew, you are very kind, and your words are appreciated. I’m kind of getting back into cars, having started but not finished any over the past few years. I intend to finish the ones I’ve started. The foil is a bit tricky but not as difficult as one might think. Two things to remember when using foil, Use a sharp ( NEW) #11 blade to cut and trim (it tears VERY easily) and have a light touch while working with it. After laid in place, I smooth and burnish with a toothpick (round) to get into creases and such, or a Qtip to smooth out. Both are to me invaluable.
Thanks again guys…
Doug
Well, sorry it’s been a little while since my last post, but I have been very busy with Spring yard work and other chores.
Anyway, here is an update. I completed the forward superstructure, and will be moving on to the aft.
I will be drilling out the portholes at some point.
Steve
Lovely work again Steve, good to see you back in from the yard.
Now thats some work there!
Thanks Doug,
Bish,
It also took a little to get back on the horse after that little “mishap”
By the way MC… I just received an entry kit for the Boeing Build when it begins. Looking fwd to it, I found a Monogram B-17 at a great price at a swap meet, and I have the 3 volumn set of the Mighty Eighth Books and am ready to build!
Doug
Doug,
Oh yeah, I love that kit. I must have build that one probably 3 time as a youngun. Did one crashed like Sheperd Paine’s 17, or at least tried to.
I’m excited to start that GB. Been waiting for it for a while.
Bish, can I join with Cyberhobby’s Sherman M4A4 in 1:35?
You sure can castel. Stik Pusher is running the roster, and I am sure will add you soon. But until then, welcome aboard.
Castel, welcome to the jungle. I will get you and your kit added to the roster this evening when I get home or tomorrow… I need a real computer and not an iPhone for my skill level (not very tech savvy shall we say?)
Hello all,
I have been watching progress on the kits. And with a break over Easter, managed to get a small part of my own kit done too.
Jibber, the Scheinenwolf was coming along very nicely. You were after a well used finish on the wooden boxes - and you did it superbly. You will have to share a few tips there for sure. The claw looks like a really nasty piece of work - and looks really heavy too.
rigidrider, the '45 Ford has come up a treat. The finish is great, and anyone who can do that with bare metal foil has my admiration. And the simple but so effective mount for the finished model complements it beautifully.
Modelcrazy - that is magnificent work. So much of my PE ends in blobs of CA glue. Can’t wait to see more of your work.
The Shinden slowly works its way to the end. Managed to prime and then paint the yellow leading edges over a white base. They have been masked off and the grey underside has been shot. Next is masking and painting the hinomarus. That will be a new experience for me…
Thanks Lost, I had a small area on the trunk that dulled for some reason, but have since reglossed and it seems to be ok now.
Man, if the Shinden wasn’t one of the coolest looking aircraft of the era… watching with interest,
Doug
JP IV coming along - needs a little streaking and pigments.
Do have a quandary and maybe some wiser armor fans can give me an educated opinion. I made the kit “buttoned up” because there is almost zero interior to be seen. I’m going to make a simple base that will evoke a kind of ambush theme. I had always intended to put on some foliage (that comes regardless) and throw on some extra gear on the back. Here’s the rub. The lines of the vehicle are really pretty simple - no fenders for instance. That means that from the modelling point of view, the rear is much the most interesting - lots of panel lines, places begging for some oil stains, spare road wheels and almost all the tools laid out. I can stick some webbing back there - or even on the side - and a backpack, but if I do put on boxes, jerry cans etc it would basically hide a almost of the detail. I think that it’s probably for that reason that no other modeller of this kit (the pics are growing daily - this is a very sweet kit) has stuck anything back there. Photos tell a somewhat different story. As noted before for some reason this vehicle did seem to attract Goebbel’s people the way other AFVs did and I’m not overwhelmed with wartime pics. But there are a few of the vehicle in convoy and they’re carrying a boatload of stuff. (One had a big oil can.) Looking at the kit, it may well be that protect the rear hull (installed individually) could have been opened up to protect a lorryload of equipment. There are some photos that appear to show the JP carrying very little - not always clear. I wonder if the junk being carried belonged to accompanied infantry. Now if the vehicle knew enemy armor was near, would it be possible that the infantry would pull their stuff off? If you were carrying a big load it would have to harm vision to the rear. At minimum I wouldn’t think that a tank would want flammable or explosive items stowed outside where they would be vulnerable to small arms fire. Anyway if a crew thought combat was near anyone think it would be likely that they’d clear as much flotsam as possible?
Eric
There is no turret to worry about fouling the traverse, so the engine deck can be packed with as much or as little great as the crew sees fit to carry. Now, normally armor is not gonna carry gear for accompanying infantry. 1) they are separate units, 2) and as such they will likely be together only for short periods of time and traditionally foot soldiers don’t like to be separated from their few worldly possessions, and lastly 3) German infantry units were not lavishly equipped as their US counterparts and tended to have a much shorter tail.
As far as vehicular equipment such as ammo and fuel goes. That stuff was is short supply by the end of the war when the Jagdpanzer IV was in service and basic loads were often the best they could manage, let alone getting extra. And as you mentioned already, you don’t want explosive or flammable items un protected by armor on your engine deck at any time. marauding Jabos will end that vehicle’s combat life real quick at any time. Water, rations, and tarps would be your best bets for stuff back there.
Also to consider, on paper a German motorized AT company would have supply vehicles assigned, including a 3 ton baggage vehicle. This was prescribed by the KStN 1149 file, issued very early 1944.
http://www.niehorster.org/011_germany/44_organ/kstn_1149_01-02-44.html
regards,
Jack
I could certainly seeing them carrying a load of junk - even things that they wouldn’t normally care to have on board. The Wehrmacht’s logistic system was in real tatters by March 45. (The only book I found specifically about the JP IV was a small but very technical study on German reactions to the T-34, KV-1 shock in both 41 and 42. If you like tech stuff, check on Amazon “Building Guderian’s Duck” 100 page study written by the Army Command College at Leavenworth. Lots of tech data and doctrine. And .99 on Kindle. No photos.) The JP IV was the first of these vehicles to be developed more or less from the ground up to be a tank destroyer. (The Stugs were originally viewed as infantry support.) It had slopping armor and the Panther’s gun - scary package. Ironically Guderian didn’t want it built - he thought tank destroyers were so crippled during a counterattack that more PZ IVs were a better trade off. Anyway, because of the vehicle’s disadvantage in a close range shoot-out (a lot of those), doctrine called for it to have infantry with it at all times to guard the flanks/rear from any allied tank or even bazooka. And I’d guess that they’d carry anything they could with no guarantee of logistic vehicles on the org chart being there. The question is whether they’d clear stuff off if they thought that there was a good chance of an imminent engagement. Sure wish there were more wartime pics. Probably flip a coin.
Eric
[/URL[URL=http://s1346.photobucket.com/user/kingtiger11/media/Trumpeter%20WR360/DSC01596_zps8xswfzmd.jpg.html]
A little more progress, mostly on the cab. I tried not to match the inner walls with the cab floor but I gave it to much of a varnished look. I’m going to tone that down a bit to make it not quite as used as the floor but a little softer. The interior cab is almost complete and I’me very close to final assembly.
Terry
Heres the pic I was supposed to post.
Terry
That’s looking really nice Terry, great work.
Since I’ve been home, I’ve started picking away at the Stuka again, in between other projects such as fixing the stove and the hot water tank. The Stuka was much more fun than those jobs.
I’ve laid in decals, and a light layer of mud as I’ve seen in photos of Rudel’s craft. I’ve stripped the old paint off of my replacement canopy and repainted. Some black and brown oils lightly streaked gave me a little bit of oil staining from the engine cowling.
I’ve got my wheels a day or two from being attached, then it’s all fiddly bits such as exhaust and antenna.
I’m not really too thrilled with having used the Eduard etch to mount the cannons, as of course the hold is a rather tentative, but for the time being I’ve not knocked them off.
