Here is a photo of the display case i made using 4 frames purchased at Michels. the frames cost $3 each and i used 4 frames. very easy to make .2 frames for the top and bottom. full piece of glass for the top and front , 2 cut pieces for the sides and the fiber board backs were used to the bottom and back. used a simple hand held glass cutter ,$6 and change. i’m pretty pleased with the results
AHHHH SHOOT !!! must of copied the wrong link…some day i’ll figure this out
(http://s97.photobucket.com/user/bubbajoe1066/media/IMG_4981.jpg.html)]
Nice! Your idea definitely has some possibilities.
Where the glass panes meet on the corners are they just sitting there or did you use an adhesive like silicon?
Thanks mitsdude… I used silicone on the top and bottom but not the sides. the glass is thin and i did not want to see silicone on the edge, i thought about adding a corner piece to hide the edge but it took away from the diorama. i smoothed the glass edges a bit with some emery cloth
that turned out really nice
Very clever idea, will have to give it a try- thanks!
