Hey guys,
Well, I actually started this one up in New York, visiting for Christmas, after being snowed-in by lake-effect snow–18 inches. Man, I miss Carolina! (I’m back now; just kidding!)
Anyhoo. this is the enigmatically-titled “early” Sturmtiger, presumably with a “Feifel” air cleaner deck–something I’ve been unable to find photographic evidence for, although I’m not going to say it never existed. In any case, as I would presume that THAT would mean it was built on a hull from a possible Eastern front Tiger, I had to scrape zimmerit into it with an exacto. Not hard to do, just time-consuming. Here’s where it was after a few hours of tinkering on the kitchen table…
The kit is missing a lot of minor little details. The first thing I noticed was that the rear exhausts were one blocky piece of plastic. I decided to make the exhaust tops a little more detailed. I cut off the tops, and drilled holes for the supports, which I"d make from .009 guitar string. When I tell you this was TINY, I mean it was TINY!!
And in progress:
And done…
All that, just to hide behind the shields…sigh…[:(]
Next, the front driver’s visor was just a shapeless hole, so I thought I’d correct that:
And filed down…I’ve also added the side skirts at this point; thinned down and battle-damaged. Note the annoyingly simple gun tube!? I’m about to correct that as much as I can next…
I used a sewing needle heated in a candle flame to score tiny holes in the gun tube, and then carefully drilled them out with a mini-micro drill–the smallest I could find! I also added the counter-weight stays on the mantlet too.
It’s ready for paint. I replaced the molded bars representing grab and hatch handles with fine wire, and also added a wire to the front light. I added hooks to the side where they should be, and detailed the crane some more. I built a new handle, added a rope/wire from fine, stretched sprue to the crane itself, and added that circular shell cradle from lead foil.
I also added a PE periscope cover. OOPs–gonna have to fill that small gap there under the upper hull…
I’ll ad some paint tomorrow. I think I’m going to go with a monotone DY scheme, or maybe just a one-color light line. Not sure yet. Whatever “hits me” in the morning…
Suggestions and critiques gladly welcomed, guys!!
