1/72 Seversky EP-1-106 / Swedish J-9 (finished and WIP pics)
Really sweet Vance! You did a great job with all the fine details. Those are some small azz seat belts[:|]. Cammo job is right on. Perfect wheel painting too! Too bad more of the engine isn’t visible.
Thanks Nathan, one of my favourite built kits now. Yes, a shame that more of the engineisn’t visible, but I was NOT going to crack open that cowling!
The seat belts … the SEATBELTS!!! Actually, those were nowhere close to being the smallest bits on the PE fret. There are supposed to be actuator bits for the ailerons. I got one pair off & folded, the next one shot off the fret & into oblivion. Then I looked at what I could actually hold the bloody things with to position them and decided on a “less is more” approach!
…lol! I go through that same sequence every time I use pe, no matter what scale
Man that is one CRAZY paint scheme!! Way to go with that! I don’t know how you 1/72 scale builders do it with all the detail Vance! It’s ALL good there bud, Joe
[:D] I guess it just comes with the territory!
Thanks Joe! Typical procedure in 1/72 scale involves strong lights, short sessions, lots of squinting… [8-|]
Gee that’s what I do in 1/48th scale…[:|]
That’s why I’m trying to get all these 1/72 kits built while I still CAN see them!!! [:P]
I’m actually about to do this plane in 1/48, except it is one of the shipments held back from Sweeden and sent to the Philippines (P-35A.) for some reason I was under the impression that the interior was finished with a coat of aluminum lacquer?? But I really have no idea. The USAF museum pics I’ve seen don’t really give a good look in the cockpit.
P.S. that was meant as a question, not me trying to say you got it wrong!! Sorry!! I really am not sure.
lol, I didn’t take that as anything BUT a question ajd3530!
You are correct, the few photos I’ve seen are laqcuered aluminum. (I’ve got one of the Squadron-Signal books for this machine). BUT! The pics are generally still Stateside, and I hadn’t seen any good “in Sweden” pics until recently. The Special Hobby instructions called for interior green so I thought, “hey, maybe the Swedes did this after arrival” & went with it.
Great job!
Love the camo scheme, but for one minute detail: the prop is waaaay too “clean” for as weathered as the plane is. (Don’t take this personally-it takes a pilot to notice this and most modelers miss it.)
The propeller should have paint chipped off along the entire leading edge, and on the back of the tips of the blades.
Please, don’t take this personally, and keep up the great work.
Klik
Next time at the airport, I’ll have to take a picture to illustrate what it mean, seeing as how this is a common problem.
DOH!!! You know what, I painted the prop quite awhile ahead of the rest of the machine, never even thought to add some wear to it!! (which I usually do!!) [bnghead] Thanks for the catch Klik [Y]
