Well, I am new to the forum and new to the process of Documenting a build, and come to think of it, I am new to airbrushing as well. So this will be an interesting learning process.
About my build. As a former ECM technician and partial crew chief I have been longing to do C-130H build for several years, but only now do I feel that my technique and ability is at the level to do myself and my unit justice. The base kit is Italeri’s 1:72 C-130E/H Hercules, but will require extensive modifications. In store are Eduards Interiorer, Exterior, and Cargo Floor photo-etched detail kits, Engines & Things Allison T-56-A-15 engine nacelles, 1:72 RBF tags, Paragon Deisigns Wheels with Flattened Bottoms, and if I can find them: Aeroclub Propellers. I have also started emailing companies to price out custom decals to make this an accurate Minnesota Air National Guard C-130H, to be used in conjunction with Draw Decals for Idaho ANG.
In addition to the Above mentioned kits I am planning on doing a great deal of exterior modification to make the model more accurate, including Flare Buckets, ECM Infrared and Radar censors, and depending on how well I can scratch build these items, possibly the LAIRCM system. Not to mention filling in certain air intakes on the model and correcting the APU details.
And when all is said and done it will be sitting on a custom built diorama display complete with 1:72 ground crew figures, load, maintenance vehicles, and AGE equipment. I already bought the Hasegawa 1:72 ground crew and AGE equipment, but I may use some of it to scratch build a more accurate cart generator. We will see how things go once I am closer to that point in the build.
Clearly this is an ambitious build, so don’t expect progress to get cranked out over night. There will be as much detail work going into this as possible. To start here are the photos of the basic model, hopefully tomorrow the sanding begins.
[View:/themes/fsm/utility/
:550:0]
The Kit
:550:0]
The Work Station
:550:0]
Need to build Pylon Flare Dispensers
:550:0]
And Armpit Flare Dispenspers
:550:0]
And Nose Flare Dispensers (and Tail Flare Dispensers)
:550:0]
And Need to build ECM Sensors
:550:0]
Need to Change the windows on the rear paratroop doors to be rectangle
:550:0]
And lastly I need those new engine nacelles. Its obvious that these are much shorter than they need to be.
This will surely be a long, long build. Thanks for reading.
-SSgt Gray.
