1/72 Lockheed P-38J Lightning/Droop Snoot by Dragon
Hello!
I’ve just completed a 1/72 P-38J Droop Snoot by Dragon. This particular variant of the famous Lightning was a pathfinder modification to lead a formation of bomb-equipped P-38s on accurate altitude-bombing runs. The mod was accomplished by removing P-38s guns and installing a Norden-eqiupped cabin in the nose of the aircraft.
Like it’s been written many times on the net, the Dragon’s P-38 is plagued by really poor fit - especially where the wings join the booms. You’ll need a lot of time and putty to build it right, and you will have to rescribe lots of panel lines in process. If you plan to build a P-38 in 1/72 take another manufacturer’s kit. If you plan to build a 1/72 Droop Snoot, you have to watch out, for the Dragon’s kit also has it’s problems here. Their idea on tackling the Droop Snoot is to replace the nose cone with a glass part (that doesn’t look right in my opinion), and putting a PE floor (of a totally wrong design) and a bomb sight inside. You are left with old panel lines (complete with case ejector ports) and no side windows neither.
I bought this kit really cheap in Germany (about $8), so I decided to give it a hand - I rescribed the front fuselage, filled the ejection ports and added two side windows, also added a few details inside. I relocated the antenna from under the nose to behind the left main gear bay, and added another antenna forward of the windscreen, made of a guitar string.
The kit OOB has the props designed to be glued in place - I converted them to rotary to better protect them from damage. I also rescribed the thread on the tires. I painted the model using Gunze metalics (Mr. Metal Color) and Humbrol paints, and also a Future-based black wash. The decals went on all right using MicroSet and a MicroSol/Mr. Mark Softer mixture.
The model really needs a lot of weight in the nose to keep it from tail-sitting. As the nose is hollow, you have to put the weight (lots of) in the engines.
OK, enough writing - here are the photos:
So that’s it - hope you liked it. Thanks for looking and have a nice day
Paweł
I dunno how folks like you, Bish and Joe Rix pull stuff like this off in 72nd scale! I really have an appreciation for what you guys do in this scale. I’ll never build in that scale but really enjoy seeing a good build in that scale. Well done! [Y]
Now that’s really nice. Sounds like you have taken a bit of a nightmare and turned it into a real beauty.
Nicely done!
Hello!
mustang1989 - you’ve put me in a very exclusive club here - I thanks for the compliment and for your kind words.
Bish - it was bad, but not very bad. I always say, if it doesn’t fit before you glue it, it’s the comapny’s fault. If it doesn’t fit after you glue it, it’s your fault :-). So I always try to make it fit after it’s glued. Took lots of time, putty and plastic shims here, but it workad :slight_smile: Thank you for your comment!
mississippivol - thanks a lot!
Thanks again for your comments and have a nice day
Paweł
Hello everybody!
I corrected a flaw in the paint I spotted on the left tail boom - that silver paint can be tricky!:
I also added the identification lights on the fuselage behind the landing gear bay:
Thanks for reading and have a nice day
Paweł
Hey Pawel,
I’ve noticed on my P-47 (in NMF) that I have the same flaw. Would you tell me how you fixed yours ? my guess is that just an additional light spray may fix it but I’m just not sure.
Hello Jay Jay,
thanks a lot for your comment. You’re right, a light coat should fix it, but since I already had decals on mine, I just brushed some Mr. Metal Colour on, using panel lines as boundary and trying to use as few strokes as I could. Then I gave it time to dry and buffed it with some tissue. Works well for small surfaces. Hope it helps, good luck with your projects and have a nice day
Paweł
Great job Pawel on the P-38. The NMF and decals look spot on. I guess I’m in for a triple nightmare since I picked up 3 of them at the last show on the recommendation of my friend that only builds 1/72 scale planes. Got the Droop Noot 5030, P-38J 5018 and P-38M 5019. I was aware of the missing windows on this one from a review that I read. I also got some resin nose guns for it. Two of them have extra pe and resin parts.
Wow, that one really scales up. It looks much larger than it is. Fantastic job!!
Hello!
PJ - thanks a lot for your kind words! Well, maybe not necessarily a nightmare, but it’s going to be a lot of work. I don’t know about the P-38M, but that Droop Snoot needs a lot of corrections to really tell the story. I found a great link to help here:
clubhyper.com/…/showandtell3droopsnootdb_1.htm
And you can forget the PE floor for it right away. The belts are usable. Also be sure to put a lot of weight in the front! Anyhow, good luck with your project!
BrandonK - Thanks a lot, it’s nice to hear that!
Paweł
Pawel
That is a fantastic link! Thanks so much for sharing and I have it bookmarked for future reference. You wouldn’t happen to have a similar link for the M Night Fighter?
PJ - you are welcome, glad I could help! As for the -M model - sorry, I don’t have anything. But give google a try, that’s what I did to find the article linked. Good thing is the Lightning is a popular aircraft.
Good luck with your projects and have a nice day
Paweł
Pawel
Thanks. Yes I have been searching so eventually something will pop up.
