1:72 DML Sherman Mk. V Build Log 02-18-10 Decals On!
Greetings, FSM Armor forum. I’ve been lurking here for a few months and posting the occasional “atta boy,” but this is the first time I’ve posted any serious content. By way of introduction, here’s my modeling CV.
I built a few armor models in high school, joined the army, went to college, spent several years teaching, and developed other interests. I’ve built the odd kit here and there, but didn’t really get back into armor modeling until last year. Now I’m working on building up my chops so I can build some good looking tanks.
One area I’ve struggled with is working with photo-etch. I picked up this Sherman kit at a local store for only $10. I thought it would be fun to try a “braille scale” tank, and I figure that such tiny parts should help me hone my skills with photo-etched brass.
When I played baseball, one of my favorite hitting exercises was to head down to the driving range, rent a bucket of golf balls, and try to hit them with a broom handle. After that, a baseball and bat seemed so huge I could hardly miss. I figure that working with 1:72 scale photo-etch will prepare me for 1:35 in much the same way.
Although the Tulip looks cool, I’ll be leaving off the rockets and building a straight Mk. V. I’m not a Shermaholic by any means, so please bear with me if I don’t know the names of all the parts. The turret is the spinny thing on top, right? [:^)]
This was a pretty quick part of this build. Each pair of road wheels were one part. The bogie casing had two parts, an outside and inside. The return roller was part of one of the bogie halves. There is a suspension piece inside each bogie assembly that is just visible from the side.
The idler wheel was one solid part. The drive sprockets were each two pieces. I’ve already built them, but to aid in the painting process I won’t attach them until I’ve put down the main coat on the tank and the tracks.
Here I’m preparing to replace the transmission cover towing lug mounts with the photo-etched brass supplied in the kit. The replacement lug mount looked like a butterfly. I folded it over by using the blade of my hobby knife as a bending guide. I included the penny so you can see just how small these parts are!
Here are the photo-etch lug mounts attached to the hull. They have a better scale thickness than the pre-mounted styrene, and the hole in the middle should just be visible when the model is painted.
Here’s the completed lower hull front. The towing lugs hang from their mounts very nicely. You can see some wisps of styrene still on the lugs. I couldn’t figure out a way to carve them off without destroying these very delicate pieces.
If you enlarge the photo, you may be able to see a break in the transmission cover band. The piece broke while I was trying to attach it to the hull. That’s how delicate some of these tiny pieces are.
The hull hatches had four pieces of optional photo-etch. I opted not to replace one styrene assembly because the brass parts were just too tiny for me to work with. I did try.
Here you can see two brass pieces: a double handle to the front and a single handle behind it.
The kit came with headlight guards in plastic or photo-etch. I chose the photo-etch and shaped them on a piece of sprue, which was about the right diameter, then glued them to the hull. The photo-etch parts have a better scale thickness and look pretty sharp.
Here’s the front with all the photo-etch applied. I also filled a couple of gaps in the transmission cover edge. I think I installed the bolted strips incorrectly in the lower hull, leaving no room for them to extend into this piece. For now I’ll fill the gaps and decide if there’s a way to get some strip styrene on there. I’m not happy with this fix so far. Any suggestions?
Welcome to the forum! Your kit is looking great… [Y] I am afraid its way too tiny for my little fat fingers if I have to deal with PE at 1/72 scale. I will be watching your process. Good luck!
[snWcm] and glad you decided to come out of the shadows and post a WIP! [Y] Nice work on the tiny PE additions to this braille scale Firefly.
The commander’s hatch got four pieces of photo-etch: a periscope guard, a handle, and two pieces of an external lock. The gunner’s periscope also got a guard, and there’s one more piece on the turret front. I have no idea what it’s supposed to be, but it looks cool.
You can also see the engine grate cover with its two tiny handles on either side. I had to carve away a lot of hinges to get the photo-etch to fit, but it’s a great looking grate.
Here’s another view of the grate cover, showing those two tiny handles a little more clearly.
I trimmed off the styrene tool clip holding the blade of the axe and replaced it with photo-etch. You can see the big gap in the turret rear here, which I’ll be cleaning up with Squadron green putty.
The tail lights are styrene, but the kit included photo-etch overlays for the light faces. I also attached two handles to the engine deck.
The kit includes Dragon’s new(ish) DS tracks, which took regular model cement very well. I’ll still be painting them separately, but put them on the kit so you can see my progress.
A friend who knows Shermans better than I do pointed out that I had placed the periscope guards incorrectly. They needed to be rotated 90 degrees. I was hesitant to attempt removing this tiny photo-etch, but it turned out to be an easier job than I had thought.
After two days of work, my Sherman is starting to look like a tank. With any luck, I should be able to finish the build tomorrow and start painting on Friday.
Yesterday I finished the build and started painting.
I mounted the brush guards on the tail lights and attached all the tools.
Squadron green putty got rid of the unsightly gap in the turret rear.
I used Testors acrylic paints, dark green for the base coat and a 80-20 mix of dark green and white for the highlight.
My lighting is off here. The Sherman looks very mint green in this photo, but it’s really a light olive drab.
I gave the Sherman an all-over wash with black oil paint in thinner. This wash should actually stain the acrylic paint. I’ve used this technique to good effect in the past, but here it looks a little splotchy. I’ll see what I can do to mellow it out during the pin wash.
I airbrushed the tracks with Tamiya’s brown, then drybrushed with Testor’s enamel “steel.”
looks real good, right now, but not to burst your bubble or anyhting but that seam on the back of the turret is suppossed to be there
Yes, but it’s not supposed to be a gap. I left the green putty a little rough to keep the look of the seam. I hope it gives a good effect.
Can I point out a few things? There shouldn’t be a seam between the top of your transmission cover and the bolt strip above it. That bolt strip was integral to the transmission cover, not to the glacis. Also the nice PE handles you have on the air intake and the engine deck, when not being used, slid down inside the grate and plate so they were just flush horizontal rods.
Hope this helps
You sir are a braver man than I.
Good Job.
G
I followed up the all-over black wash with a pin wash using Indian red and Van Dyke brown. Once the washes were dry, I mixed up an olive drab drybrush with oils. I mixed equal parts titanium white, yellow ocher, and sap green.
I really liked the effect of using oil paints for my drybrush. The drybrush went on very smoothly, and I was able to soften some areas that were overdone by applying a little thinner to the affected area.
The result is a battered looking olive drab finish. I was worried when I saw how rough the black oil wash looked, but now that the process is complete, I’m very happy with the color of the tank.
T26E4, I was worried about that gap on the transmission cover. It’s a little too late now to patch it, but I think I’ll be able to cover it with some stowage.
Hey Scott,
Looks like we have dueling 1/72 scale DML Sherman builds going:
/forums/t/125246.aspx
How are you liking yours? It looks like (minus the wading trunks) your kit actually has more details in PE than the one I am doing. Are you going as cross-eyed as I am?
I really like the finish you have applied to it - I agree, your drybrushing came out pretty darn well.
Keep up the good work!
Yes, bbrownii, I’ve been following your build with great interest. The kits are very similar, and I’ve enjoyed this build so much that I’ve thought of trying the deep wading kit next. I envy you your photovisor. I don’t have one, and I felt the lack during this build.
I hear ya, my friend. Without that thing, I’m quite sure I’d be getting eye-cramp…[8-|]
The kit came with decals for the 1st battalion of the Coldstream Guards, with appropriate markings for the rocket-equipped “Tulip” tanks. I don’t have any other 1/72 decals, so I went ahead and used the kit decals, even though I didn’t want to mount the rocket launchers. Perhaps the unit had the same markings before the tanks were modified?
I airbrushed the paint with acrylic clear gloss, applied the decals, airbrushed again with acrylic clear gloss, and finally sprayed with clear flat enamel. The tank’s finish is looking better now that it’s flat.
The “52” decal had to fit under this bit of equipment, but of course the model was already built. So I carefully trimmed the decal with my hobby knife to get it to fit.
Yes, I did paint the road wheels a rubbery color. They’ll probably be all covered in muck soon, but here’s proof that they were once the proper color!
A really nice, detailed WIP, Scott. Nice job on all aspects here–the delicate PE, the shading on the painting, and the weathering. A top-shelf “Braille scale” build!
I can’t give you any advice on Sherman specifics though–I build mainly your tank’s opponents, lol!
I don’t mind using PE but, in braille scale? That makes my hands want to cramp and my eyeballs implode. Well done sir
Cheers
Dave
That’s how I felt doing the PzIV out of the box with NO PE.
Good job sir!
G
