Hello all. My next build is going to be the Mighty Mo from Revell. Any pitfalls? Any aftermarket PE parts available? Anything i should do with this kit? Any advice or assistance is always apprciated.
LOL…Nevermind…I just read all the articles about this kit on this forum…Should have searched first, started topic second. Bone head move. Sorry
Oh no worries.
Don’t do it.
Trumpeter makes a series of very nice Iowas in 1/700 which is a good scale for a ship that big.
Go big or go home! Get Trumpter’s 1/200 Missouri ! So what if it’s ridicously big. There is a ton of PE and aftermarket bits to keep you busy for quite a while. Take out a second mortgage and buy everything you need or want for it. you only live once! LOL Besides, I don’t want to be the only one on here building this big ol’ girl. Happy building my friend!
Repeat! (that first salvo…) Don’t do it!
BUT wait! I had a g#~*-d@%% 2nd thought:
Give it a shot. If you have the skill, cut off all the superstructure parts and add them onto some Evergreen V-groove .30 or .40 sheet. Waterline it.(That statement caused me some hesitation- I like Full hull). Then add some GMM or TMW 1/500 PE, dig thru some WIP’s for ideas, and Paint it any way you want and you will have something no one else has; a 1/535 USS Missouri the way Revell should have made it back in the 50’s.
My suggestion on details: Keep the 40mm, that way we know it is the Revell kit. Dump the 20mm and use PE or steal some from a Renwal North Carolina or Washington. Get more sheet plastic of .010" or .015" size for the main deck 20mm splinter shielding and all deck areas that are steel like Aircraft handling at stern and Anchor Chain areas at Bow.
Be aware you can expect to spend a lot of time on this so, build something else first. Make this an on-going project. I will watch and assist if I can as I started the cutting and have the Plastic sheet and some 20mm guns but I have not progressed any further except to collect pictures and links to other “Builds”.
Nino
P.S. I am sanding down the Evergreen V-groove at the “steel deck” areas to make the .010 sheet fit better. Sheet plastic for Chain area at bow can sit proud.
or replace all the 20’s & 40mm’s with 3d printed versions.
http://www.3dmodelparts.com/1-500-quadruple-40-mm-bofors-autocannons-with-shields-8-pcs/
http://www.3dmodelparts.com/1-500-single-20-mm-oerlikon-cannons-pedestal-mount-16-pcs/
Hi;
I feel sorry for you. If any of the other REVELL ships are an indication give it away. Then, go to your Hobby source and purchase either Trumpeter’s Iowa or Missouri in 1/200. Yes, you will have to mortagage your firstborn, But whatta kit !
If it wasn’t for their small size I would also recommend any 1/700 scale, Tamiya, Hasegawa, or Trumpeter version. Even in that scale they are quite large!
Because of my Predeliction for 1/87 scale this is a problem. My Mo is very, very Large. Not even out of the planning stage , after ten Years.
Anyway, I must warn you.There are some Major inaccuracies in this kits hull. The sweep from midships to the bow is too abrupt and narrow. It can be fixed. With a lot of work. This is supposed to be a gentle transition from Midships to the bow. Not the apparent sharp curve the Revell kit has . Look at any 1/700 kit of this class and you’ll see. Before her mods the first time, I spent time on her deck pondering her fate.
She was in Bremerton, Bow in or close to the bottom and filthy! Even the Marine guard wasn’t Ship-Shape and Bristol fashioned. If he’d been one of mine I would’ve written him up for Slovenly Appearance!( I wasn’t in the Corps yet ) and I was in civvies!
Even being on liberty from my Destroyer I was grossly dissappointed the way she had been cared for. The U.S.S. Rochester( Cruiser) on the other side of the pier was cleaner and in better shape!
Tank-Builder, If you get it started in that scale I would drive over to you just to see it in that scale ! that has to be pushing 10ft, correct?
Hi,
I guess it should be noted that this is a fairly old kit dating back to the early 1950s (according to scalemates.com). As such the lower hull isn’t necessarily all that accurate, and you may experience problems attaching the single piece hull to the main deck (I know I did when I was a kid).
Additionally, alot of the detail (like smaller calibre guns) are molded onto the deck, and parts like the catapults might seem fairly crude when compared to modern kits.
As such, as you can likely see from some of the responses here, and other previous posts on this forum, this kit probably doesn’t compare that well to other more modern models of the ship.
That said though, it is a very readily available and usually not too expensive kit that can be a fun build both newer modelers that want to build something interesting, cheap, and not too taxing of their abilities, as well as more experienced modelers interested in seeing what they can do to “improve” the “kind of rough” starting point that the kit represents.
As such, if I were you, if I already had this kit in my possession, I would probably start with this kit, experimenting around with scratchbuilding, modifying, but I probably wouldn’t try to spend too much money on anything like photo etch or other after market parts (if they exist).
Later on, once I had finished, if I were still lnterested in having a detailed build of the ship, I might then look at a more modern casting in either 1/700 or 1/350 scale.
Hope this helps
Pat
