1:48 Tamiya F4U-1A Corsair "Pappy" Boyington's 883
Here’s a post I’ve been wanting to share for a while now but I’ve been putting off for other things that become more of a priority. I’ll show it as a WIP but it’s been finished now for about 10 or so months. This was the build that I really improved a lot on and put some newer skills under my belt. It’s far from perfect but I enjoyed the opportunity to push weathering a plane with the painting process before I sealed anything at all.
I won’t spend too much time on the little things as most of you are likely to be familiar with Tamiya’s Corsair. It’s an easy build and comes together beautifully. I’ve made some changes here and there to improve the accuracy of the build and I’ll highlight those. Also, I’ve almost finished making a light-box to photograph some of these planes with and when I get it the way I want I’ll include a few more at the end. =]
2012-12-18 11.46.50 by brittvallot, on Flickr
Here is the test fitting. The intercooler pieces I’ve sanded down and opened up with an exacto blade. You’ll see this better later.
3800_785386472744_1187751654_n by brittvallot, on Flickr
Unfortunately I couldn’t find any better photos of the cockpit. It’s actually one of Tamiya’s better ones in my opinion. On the dash, I’ve started with a Flat Black and followed up with some dry brushing of Tamiya’s Flat Aluminum [XF-16] I think and came back over that with some dry brushed Flat Red Brown and then more dry brushed Flat Black. This is generally the way I’ll paint a heavily weather plane’s visible dash.
Skipping ahead, I’ve cut out the piece where the kit exhaust tips go. Instead I’ve opted to bend some brass tubing to make individual exhausts. I’ve mounted them into the back of the cowl where the engine fits to. I’m less confident now that the holes I drilled to support them had part of the exhaust manifold passing through here, but as it works out I need the wiggle room to place each three in there…so…it kinda worked itself out. It’s covered; so I’m fine with it. =] These exhausts are also filed down as thin as I could make them.
36500_785386612464_1436091686_n by brittvallot, on Flickr
72509_785386672344_241092928_n by brittvallot, on Flickr
I did grab this little gem. A Quickboost R-2800 and the Vector cowling ring and motor mounts to upgrade the engine area. =D
486114_785386722244_1175902941_n by brittvallot, on Flickr
This photo shows a new trick I come up with to display the landing light. I cut a very small rectangle of mylar sheet (very thing). I put two bends in it. One is for the base to glue it and the other is to show the filament which gets painted Flat Black. The housing for the light is painted in Flat Aluminum and the “glass” is placed on and masked. This was also one of those little, proud “Ah hah!” moments I had.
10262_785387016654_409663015_n by brittvallot, on Flickr
Since I’ve been displaying all my planes lately in flight, this required some scratch building for the flaps. There are some tabs that flip over when the flaps are in the down position. So since I’m cutting them and placing them up, they needed to be added on.
Before:
394855_785386797094_1694841448_n by brittvallot, on Flickr
After:
25972_785387031624_1127837959_n by brittvallot, on Flickr
582728_785387076534_2066892403_n by brittvallot, on Flickr
2013-01-06 22.48.56 by brittvallot, on Flickr
2013-01-06 23.08.03 by brittvallot, on Flickr
Next, comes the landing gear which had to be placed up as well. When I can include them I certainly aim to. Here I had to cut and shorten the strut so it would be in the up position.
2013-01-04 12.12.15 by brittvallot, on Flickr
2013-01-04 13.13.33 by brittvallot, on Flickr
Also, I had to go back and allow the space between the doors to be seen somewhat after they’d been glued shut.
2013-01-06 22.49.14 by brittvallot, on Flickr
Next, I fixed up the rudder. Since so many of these parts come attached, I always take time to cut them out and reattach them in a position according to how the plane is flying. Also, there’s often a small gap that gets left out when they are part of the mold for the fuselage taking away from the realism some. Just my two cents.
65857_785386936814_780379083_n by brittvallot, on Flickr
Here’s a quick shot showing a test fit of the engine/cowl and the intercooler opened up from the original mold.
75069_785386856974_1239554466_n by brittvallot, on Flickr
Next up, I’ve closed the doors, preshaded the panel lines, and painted the undersurface. On Boyington’s 883, there’s a photo where the door on the port wheel bay is stained from something. Possibly fluid/oil from something that busted or leaked during a flight. You’ll see later how I’ve added that on.
537155_785387121444_378564786_n by brittvallot, on Flickr
2013-01-11 08.08.30 by brittvallot, on Flickr
I’ve painted on the tri-color scheme as best as I could make it from photos taken of the actual Corsair. The left side of the fuselage had to be guessed at some what as most pictures are of the right.
2013-01-11 08.08.55 by brittvallot, on Flickr
2013-01-11 08.09.20 by brittvallot, on Flickr
2013-01-11 08.09.05 by brittvallot, on Flickr
I post-shaded some panels that stood out as high trafficked and those that were fabric and always wore more quickly. I even put a little more on the right side as a certain photo showed the Corsair stowed next to a break in the trees. More light reached the right half of the plane. I’ve seen this same thing happen to my mother’s Oldsmobile Cutlass Sierra. Half the hood had oxidized more than the other as the sun dipped between our house and my neighbor’s reaching into our garage. Thought I’d make my build unique and include a feature like that. Seems a little silly now. =]
Onto the Pratt & Whitney R-2800! I’ve added some brass rod to make up the braces for the cylinder heads and stretched some sprue to make up the ignition cables. The front here was also painted a slightly different blue from an up angle to show weathering from this seriously large engine poking through the front of the cowl.
2013-01-07 13.49.32 by brittvallot, on Flickr
2013-01-07 14.27.37 by brittvallot, on Flickr
2013-01-07 17.28.19 by brittvallot, on Flickr
2013-01-07 17.29.58 by brittvallot, on Flickr
I’ll stop here for now and finish later tonight. =]
Looking really good… keep it up
Looks great so far bvallot. I’m getting inspired to drag out my Tamiya Corsair and give it a whirl. I’m considering doing Boyington’s 915 Corsair that he was shot down in. I’ll be following your progress.
Nice work!
Thanks Joe! I’m going to wrap up most of this tonight, but there will be a few more pics to post when I can get them ready. Here goes:
I realized as I was just reading thru this that the painting you’ve seen so far was done over the Intermediate Blue. The post shading comes next. My mistake. I brought the Insignia White up a little higher than needed and brought the Intermediate Blue over the rest of the upper surfaces. Just to recap it. =]
The actual post shading comes next:
(http://www.flickr.com/photos/98177124@N06/11840614155/)]
(http://www.flickr.com/photos/98177124@N06/11840614155/)]2013-01-15 15.20.50(http://www.flickr.com/people/98177124@N06/)]brittvallot by , on Flickr
Here I’ve very carefully loaded a small brush with alcohol and lightly removed the top layer where fuel has washed away the top layer of paint. Soon after I came back with the same Medium Blue I mixed and filled in whatever was overdone. With the darker blue that’s on top, I took a small sample of that and darkened it some and loaded a small fine brush again and touched up around the edges of what was weathered as per the WW2 photos of Boyington’s Corsair. The ribbing was done with the Medium Blue. For the left side of the fuselage I had to take some artistic liberty to imagine how the fuel would course down. I didn’t want to mirror the right side and I didn’t want one side to compete with the other for the eye’s attention. So I left it somewhat understated but still present.
(http://www.flickr.com/photos/98177124@N06/11841047454/)]
(http://www.flickr.com/photos/98177124@N06/11841047454/)]2013-01-15 15.20.37(http://www.flickr.com/people/98177124@N06/)]brittvallot by , on Flickr
(http://www.flickr.com/photos/98177124@N06/11840901153/)]
(http://www.flickr.com/photos/98177124@N06/11840901153/)]2013-01-15 15.21.04(http://www.flickr.com/people/98177124@N06/)]brittvallot by , on Flickr
2013-01-22 01.02.09 by brittvallot, on Flickr
The skid paint was warmed up a notch since it would have been walked on with sandy, muddy boots. When I paint these, I mask them off and paint harder lines over the sides to mark the boundaries of them, but leave the middle less opaque in spots to give the illusion of use. When I don’t have a photo to follow, I use my best guess based on a 1:48 sized gait and where the skid paint lies on the wing. The dark blue field for the insignia was cut for a mask and painted on.
2013-01-17 13.47.45 by brittvallot, on Flickr
As for the numbers… If you look carefully in the photos of the actual craft, you’ll notice how the previous numbers were painted over with a color similar in value to the dark blue field of the insignia, and then the white “883” was painted on top. So I cut out a mask and did the same. Made my dark blue “cover up” and a mask for the numbers (which took several tries at this size) and painted my white on top. Simple! =] If you look over at the insignia you’ll also notice where it looks like they repainted it a little lower. The original color looks faded beneath the new stars and bars. So I made a mask to paint this feature…lightened up the dark blue I was using and put it on there. I did the same for the other side with this logic in mind…if they lined it up according to something based on the size of the mask they would use then perhaps they kept it the same on the other side. Soooo, that’s what I did. =]
2013-01-17 13.47.35 by brittvallot, on Flickr
2013-01-17 13.47.19 by brittvallot, on Flickr
2013-01-17 13.46.07 by brittvallot, on Flickr
If you look close, I even included the overspray from the mask they used when painting the numbers! =D
Here are the photos I referenced:
Boyingtonin883 by brittvallot, on Flickr
Screen shot 2012-08-14 at 2.38.01 AM by brittvallot, on Flickr
If you look at what I’m pretty sure is a formation light on the right wing, it’s a feature that is left out of nearly every F4U-1 I’ve ever seen modeled. But here it is on Pappy’s plane. You’ll see it on mine towards the end. All I did was cut a silver of clear sprue, filed it down to shape, buffed it (CAREFULLY, it’s so tiny) and gave it a thinned coat of Tamiya’s Metallic Grey.
Zu64428 by brittvallot, on Flickr
VMF-214 CO Boyington at Barakoma Airstrip on Vella LaVella Island-1 by brittvallot, on Flickr
The bulk of my weathering on this build came from these four photos. Some liberties wear taken elsewhere based on normal wear patterns of corsairs from this time period during this campaign. The colors selected were also altered slightly to fit the values seen in these photos. I never paint straight out of the bottle.
Jumping ahead some more, I’ve got everything sealed with future and decals are placed on. As I’ve outlined before I cut the stars and bars out of the actual kit decal and placed them where they would go normally over what I’ve painted. Everything gets resealed in future and some oil washes. I need to find some pictures of underneath to show the exhaust staining. I’ll look for those tomorrow.
2013-02-01 13.22.47 by brittvallot, on Flickr
I also played with the MiG pigments for the first time here. “Sand” was placed in the cracks of things I might imagine it would find itself. =] Very subtly though…
2013-02-01 13.20.18 by brittvallot, on Flickr
2013-01-31 11.04.38 by brittvallot, on Flickr
I had to make a new canopy as I goofed painting the first one. I was coming up with a solution at the time I took these. I would later use the other bubble top and trim and sand thin two pieces of plasticard cut to fit where they should go.
2013-01-31 11.03.40 by brittvallot, on Flickr
2013-03-11 23.05.08 by brittvallot, on Flickr
2013-03-11 12.45.01 by brittvallot, on Flickr
That’s it there. Can’t even tell huh?! =P
And to end it for now, here’s a candid shot I found from my phone to show her complete, mounted, and looking pretty. =]
2013-04-04 12.00.40 by brittvallot, on Flickr
I’ll follow up on those other pics as soon as I track them down.
Bvallot, thanks a pants load for taking the time to post this and walking us through your build process. One of the finest weathering jobs I’ve seen on a Corsair. That’s it, Pappy’s “915” is my next build…I’ve been itching to build that Tamiya Corsair (a Hobby Lobby buy back in the day…so sad) so you’ve convinced me. I’m going to try to make stencils for the numbers. A digging I go for pictures of that bird…
Joe
HA! Nice. That’s encouraging to hear. I’m constantly distracted into doing another plane (other than the one I need to be doing) because of all the posts I see from you. =] I’m eagerly waiting to do his Flying Tiger actually. I just need to find some decals of the Chinese roundels. I’d hate to buy something else just to kit bash.
I do have a few more photos of the exhausts, the nav lights, engine, and something else I can’t quite think of cause it’s so late. I’ll put em up.
Also looking forward to your 915. *thumbs up.
For those of you who do armor, notice the Ford bomb truck in the background of one of the photos.
Outstanding job on the finishing. Nice to have added the photos of what you were attempting, and was beautifully successful at, to reproduce.
I admit I’m a little less up on land based vehicles during WW2. Can you elaborate what was the Ford bomb truck was for?
Wingnut: Always appreciated. =]
Check this out.
http://www.ebay.com/itm/EagleCals-Decals-1-48-CURTISS-P-40-TOMAHAWK-A-V-G-1st-Squadron-Flying-Tigers-/131053381318?pt=Model_Kit_US&hash=item1e8363e6c6
I think one of these is even Boyington’s P-40…not sure. Sky Models also has a nice P-40 sheet with quite a few AVG subjects on it as well. Its on Ebay from time to time.
Joe
Sweet! Thanks Joe. I’m looking into now. =]
The Ford GTB bomb service truck was used to pickup and carry bombs for installation on the aircraft, and also used to tow bomb trailers to waiting aircraft. It was kind of a rare vehicle as not many were made compared to the Chevrolet M-6 truck.
www.greatmodels.com/…/display.cgi
http://olive-drab.com/idphoto/id_photos_gtb.php
bvallot,
That’s a heck of a corsair! Love the weathering. Found that the pictures you posted of 883 were from films of Boyington, so had to watch those. Makes me want to dig out my Tamiya Corsair. [:)]
Gary
Bvallot, all I can say is wow! I’m sorry I’ve not posted before now, my health has been pretty poor lately and I just spent a week in the hospital with pancreatitis… so this is my first chance to get to see your take on 883. I certainly learned a lot and you’ve given me some ideas. I’m pretty sure I’m going to revisit this build, in fact I’m looking at a Hagasawa combo that includes 813 and I believe 740. First things first, and that’s to pick up an airbrush :wink: Thanks so VERY much for posting this, Raymond
No kidding?! The pancreas is no joke. For such a seemingly insignificant organ, it’s quite the lynchpin! I hope you’re on the mend. =] And many thanks for sharing your own build on here. Who knows when I’d have got around to ever putting this up. I can tell you this much that I felt pretty rushed putting all this on here. I glossed over quite a few steps as they seem pretty redundant to most folks on here, but if you happen to have any questions at all I’d be happy to share some of my tricks.
I still have a few more to post. I’m trying to get my light box up and running so I can film things more properly. So I’ll be including more of the underside, the exhausts (and staining) a few miscellaneous items like the actuators for the elevators/ailerons/trim tabs and the like. This was the first plane I tried my hand at some of that kind of scratch building. It’s by no means perfect, but you’ll still be able to see the process and maybe even make it better yourself when you try it. =] And yes!! go pick you up an airbrush stat!! It’ll make a world of difference.
Yeah, slowly but surely on the mend. Wish I could say it’s my first bought with this crap, but I’ve been dealing with it off and on for over 10 years… may have left me a diabetic after the first three times, though we’re not sure which came first. Sucks, but you live the hand your dealt… no need crying about it.
Going to go look at air brushes tomorrow and trying to sweet talk the wife into ordering me the hasegawa kit in time for my birthday in a few weeks :wink: So much to do, so few hours in the day… And I’ll take you up on your offer… First by asking: are you using acrylic paints or some akin to Testers model paint. I know, a total rook question, but… Raymond
I hear ya. I’m in the healthcare industry. So biologies were a big part of my schooling. And no worries about the simple questions. Most of mine start that way too.
I use acrylics to paint with mostly. Tamiya specifically. They mix well and more importantly there are plenty of them. I nearly always mix my own color to paint with too which they’re good for. They’re also fairly forgiving too. One thing to keep in mind though is that acrylics are plastic based. They will get thick on you and begin to hide or fill in any surface detail you have in front of you. So make your coats thin. I use simple rubbing alcohol (isopropyl). The higher the alcohol percentage then the faster it will dry on the surface you’re painting. The isopropyl is the thinning agent and when it’s atomized by your airbrush, it provides more surface area for air to surround the alcohol which in turn allows it to evaporate more quickly leaving behind only your pigment. I’ve yet to encounter this problem, but if your paint starts to look dusty it’s likely that your brush is too far away from the subject. Your paint is beginning to dry before it hits the surface of what your painting. It’ll probably never happen to you but if it should…now you won’t scratch your head confused of how to proceed. =] You could also mix with water but your dry times could be longer and your paint may possibly run if it gets thick in spots.
Hope that helps to get you started.
Answers a lot! Thanks!!! Raymond
